Introduction
This guide shows you how to replace the motherboard in the Surface Studio
Lay the Surface face down on a padded surface
Remove the four rubber feet at each corner concealing the Torx screws
Remove the four Torx screws under the rubber feet.
Two screws on the upper corners are longer than two screws on the lower corners.
Attach suction cups to the bottom cover and then pull on the suction cups to free the bottom cover.
Lift the black plastic flap attached to the data cable retainer and rotate it away from motherboard.
Pull the data cable out of its socket.
Disconnect the data cable connecting the headphone jack to the SD card slot modular board
Remove three torx screws holding the SD card slot modular board
Remove the SD card slot modular board
Remove a torx screw holding the headphone jack
Remove the headphone jack
Remove three 5mm hex mounting posts
Sir I need help
Microshoft surface studio 2 plus 27”
This device work bud display do not light black screen any idea sir how to fix ???? And Usb keyboard work cap’s look work
Sir i need help
Sir i need help
I have microshoft surface studio 2 plus 27” this device do not display but always work screen black how to fix plz help me sir
6 other people completed this guide.
3 Comments
I would like to find a new motherboard too… 32gb ram though.
