Supreme Trimmer Blade Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
45
Past 30 Days:
140
All Time:
893
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your Supreme Trimmer has a broken T shaper blade this guide will help you manually replace the blade at home. If your blade is broken or chipped it is unusable and a safety hazard. Your blade is what actually cuts the hair on your client so any damage should be found immediately. If you were to use it in that condition it would cut the skin of your client. When barbering a trimmer is a very important tool and must always be ready for use and instead of buying a new trimmer just use this guide to manually do it yourself and save money. In the first steps it make sure you clean any outer or inner hair which is something I highly recommend.
Tools
    1. Supreme Trimmer Blade Replacement, Blade: step 1, image 1 of 2 Supreme Trimmer Blade Replacement, Blade: step 1, image 2 of 2
      • Remove any excess hair that could be in the way before you continue.
      Ask FixBot
    2. Supreme Trimmer Blade Replacement: step 2, image 1 of 2 Supreme Trimmer Blade Replacement: step 2, image 2 of 2
      • Remove the screws on the back of the trimmer in order to remove your old blade.
      Ask FixBot
    3. Supreme Trimmer Blade Replacement: step 3, image 1 of 1
      • Open up the new t shaper blade.
      • Make sure your new blade isn’t broken as well.
      Ask FixBot
    4. Supreme Trimmer Blade Replacement: step 4, image 1 of 2 Supreme Trimmer Blade Replacement: step 4, image 2 of 2
      • Remove any excess hair that may be in the interior of the trimmer so it wont get in the way later on.
      • Align your new blade with the smaller blade to make sure it is perfectly even and won't cut anybody.
      Ask FixBot
    5. Supreme Trimmer Blade Replacement: step 5, image 1 of 2 Supreme Trimmer Blade Replacement: step 5, image 2 of 2
      • Screw back the two screws on the back.
      • DO NOT screw the back really tight since it causes the trimmer to not work as well.
      Ask FixBot
Finish Line
2 other people completed this guide.
Gonzalo Garcia
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 45
Past 30 Days: 140
All Time: 893
