Shop the Holiday Gift Guide
Supply Tube
View statistics:
Past 24 Hours:
0
Past 7 Days:
8
Past 30 Days:
24
All Time:
564
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Supply Tube
Introduction
Go to step 1 ↓
Prereq-only guide for disconnecting the supply tube from a gravity flush toilet.
    1. Supply Tube, Shutting off the Water Supply to a Toilet: step 1, image 1 of 2 Supply Tube, Shutting off the Water Supply to a Toilet: step 1, image 2 of 2
      • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
      • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
      Ask FixBot
    1. Supply Tube, Supply Tube: step 2, image 1 of 3 Supply Tube, Supply Tube: step 2, image 2 of 3 Supply Tube, Supply Tube: step 2, image 3 of 3
      • Place a bucket under the supply tube to catch any dripping water.
      • Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
      Ask FixBot
Author
with
Ron Davis
33,851 Reputation
13 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 24
All Time: 564
