Supersonic Matrix SC-91MID Back cover Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Supersonic Matrix SC-91MID Back cover Replacement, Back cover: step 1, image 1 of 1
      • Use an opening tool to separate the back cover of the tablet by wedging the tool into the crease between the back cover and touchscreen.
      • Work your way around the perimeter of the tablet to detach the back cover and remove it carefully so you don't rip any cables attached.
      Ask FixBot
    2. Supersonic Matrix SC-91MID Back cover Replacement: step 2, image 1 of 1
      • Use a spudger to carefully disconnect the display ribbons from the motherboard.
      Ask FixBot
    3. Supersonic Matrix SC-91MID Back cover Replacement: step 3, image 1 of 1
      • To remove the battery, use the spudger to pry the battery up and away from the tablet.
      • You might have some difficulty removing due to glue holding the battery in place.
      • Work your way around the perimeter of the battery with the spudger or opening picks gently so you don't bend or puncture the battery.
      Ask FixBot
    4. Supersonic Matrix SC-91MID Back cover Replacement: step 4, image 1 of 2 Supersonic Matrix SC-91MID Back cover Replacement: step 4, image 2 of 2
      • Use a spudger to remove the speakers.
      • To remove the motherboard, remove the three screws that hold the board in place with a Phillips screwdriver.
      Ask FixBot
Jake
213 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 12
All Time: 238
