Superficial Drywall Ceiling Crack Repair
  1. Superficial Drywall Ceiling Crack Repair, Superficial Drywall Ceiling Crack Repair: step 1, image 1 of 2 Superficial Drywall Ceiling Crack Repair, Superficial Drywall Ceiling Crack Repair: step 1, image 2 of 2
    • Use a utility knife or five-in-one to remove loose paint or drywall from inside the crack.
    • Don’t gouge the ceiling but firmly scrape parallel to the crack. Scraping perpendicularly to the crack will only cause more damage.
  2. Superficial Drywall Ceiling Crack Repair: step 2, image 1 of 3 Superficial Drywall Ceiling Crack Repair: step 2, image 2 of 3 Superficial Drywall Ceiling Crack Repair: step 2, image 3 of 3
    • Use mesh tape to tape over the crack.
    • Try to use long pieces of tape, if possible taping the entire crack with one piece.
    • It is also important to keep each piece of tape centered on the crack.
  3. Superficial Drywall Ceiling Crack Repair: step 3, image 1 of 2 Superficial Drywall Ceiling Crack Repair: step 3, image 2 of 2
    • Use either a five-in-one or a putty knife to spread the compound.
    • Spread drywall joint compound over the tape so that it appears flat.
    • Use more joint compound than you need rather than less. You will sand off excess later.
    • Make sure to cover the tape completely.
  4. Superficial Drywall Ceiling Crack Repair: step 4, image 1 of 2 Superficial Drywall Ceiling Crack Repair: step 4, image 2 of 2
    • After the compound has completely dried sand down any ridges that resulted from the putty knife.
    • This step will be messy! Everything in the room will get some dust on it, so either use dropcloths or be ready to clean when you're done.
    • Also, be careful not to get dust in your eyes, or inhale dust. You may wish to wear goggles and a dust mask.
    • Don’t sand into the tape.
    • You still want the compound to cover the tape and its contours completely.
  5. Superficial Drywall Ceiling Crack Repair: step 5, image 1 of 1
    • Prime and paint the ceiling.
    • Use a primer and paint that has been matched to your ceiling by a paint shop.
    • The primer can be any color that is the same or lighter than your ceiling color.
Austin Hochstetler
976 Reputation
1 Guide authored
Cal Poly, Team 30-1, Green Spring 2015 Member of Cal Poly, Team 30-1, Green Spring 2015
CPSU-GREEN-S15S30G1
4 Members
7 Guides authored
Past 24 Hours: 25
Past 7 Days: 150
Past 30 Days: 987
All Time: 133,911
