Motorola Droid X Battery Replacement
    1. Motorola Droid X Battery Replacement, Battery: step 1, image 1 of 2 Motorola Droid X Battery Replacement, Battery: step 1, image 2 of 2
      • Locate the power button at the top of the phone. Depress power button for 2 seconds until a menu appears.
      Ask FixBot
    2. Motorola Droid X Battery Replacement: step 2, image 1 of 2 Motorola Droid X Battery Replacement: step 2, image 2 of 2
      • Once the menu appears, select the "power off" option. Wait until the phone is completely off.
      Ask FixBot
    3. Motorola Droid X Battery Replacement: step 3, image 1 of 2 Motorola Droid X Battery Replacement: step 3, image 2 of 2
      • Place thumb on the back cover, and push down towards the bottom of the device. Once the cover releases, pull it away from the phone and set it aside.
      Ask FixBot
    4. Motorola Droid X Battery Replacement: step 4, image 1 of 2 Motorola Droid X Battery Replacement: step 4, image 2 of 2
      • Find the yellow pull tab located in the upper left corner. Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
      Ask FixBot
    5. Motorola Droid X Battery Replacement: step 5, image 1 of 1
      • The battery has been successfully removed.
      Ask FixBot
5 other people completed this guide.
Alfred Rosen
117 Reputation
1 Guide authored
Cal Poly, Team 18-40, Regan Fall 2012 Member of Cal Poly, Team 18-40, Regan Fall 2012
CPSU-REGAN-F12S18G40
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 22
All Time: 4,352
