Super Nintendo Controller Port Replacement
  1. Super Nintendo Controller Port Replacement, Outer Case: step 1, image 1 of 1
    • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
  2. Super Nintendo Controller Port Replacement: step 2, image 1 of 3 Super Nintendo Controller Port Replacement: step 2, image 2 of 3 Super Nintendo Controller Port Replacement: step 2, image 3 of 3
    • Carefully flip the unit back over.
    • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
  3. Super Nintendo Controller Port Replacement, Eject Button: step 3, image 1 of 2 Super Nintendo Controller Port Replacement, Eject Button: step 3, image 2 of 2
    • Lift the right side of the eject lever out of the housing.
  4. Super Nintendo Controller Port Replacement: step 4, image 1 of 3 Super Nintendo Controller Port Replacement: step 4, image 2 of 3 Super Nintendo Controller Port Replacement: step 4, image 3 of 3
    • Pull the metal bar out through the right side of the eject lever.
    • Make sure to keep track of the spring located on the left side of the lever as it may shoot off when removing the metal bar.
    • When reassembling, the procedure becomes more difficult due to the spring (marked red). We recommend that one person hold the spring in place (picture 3) while another person slides the metal bar back into the left housing, and slide the eject lever onto the metal bar.
  5. Super Nintendo Controller Port Replacement, Controller Port: step 5, image 1 of 1
    • Lift the controller ports out of the housing, this should be done without much force. Take note of the location of the ribbon cable connection.
  6. Super Nintendo Controller Port Replacement: step 6, image 1 of 2 Super Nintendo Controller Port Replacement: step 6, image 2 of 2
    • Carefully remove the ribbon cable from its port.
James Shirley
967 Reputation
2 Guides authored
Cal Poly, Team 4-47, Amido Fall 2010 Member of Cal Poly, Team 4-47, Amido Fall 2010
CPSU-AMIDO-F10S4G47
4 Members
25 Guides authored
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 119
All Time: 33,508
