Installing Super Nintendo Cartridge Board
  1. Installing Super Nintendo Cartridge Board, Cartridge: step 1, image 1 of 2 Installing Super Nintendo Cartridge Board, Cartridge: step 1, image 2 of 2
    • On the bottom front corners of the cartridge you should see two screws using the 3.8mm "Gamebit" screwdriver bit. A 3.0U Spanner bit can also get them out.
    • Once the screws are out, slide the front part of the plastic casing down to clear the tabs on the top of the case.
    • The two halves of the case should open easily.
  2. Installing Super Nintendo Cartridge Board: step 2, image 1 of 1
    • At this point the game board and pins are freely accessible.
    • Here you can fully clean the pin set and inspect for damage to the circuit board.
    • Cleaning the pins is the easiest part; use a cotton swab and either a rich mixture isopropyl alcohol or Brasso. Other people swear by an eraser(the white kind), but it can lead to damage if you're not careful. Personally, Brasso works the best.
  3. Installing Super Nintendo Cartridge Board: step 3, image 1 of 2 Installing Super Nintendo Cartridge Board: step 3, image 2 of 2
    • NOTE: The top edges of the board are made asymmetrically so it can only go into the casing one way. Near the Blue Circles
    • Games with battery backup (allowing for save games to be stored in SRAM) allow access to the battery at this point for replacement. Most of the time the battery is a button cell: CR2032.
    • The battery is soldered in. You will have to break it out and re-solder the new battery in.
BWest
3,375 Reputation
2 Guides authored
OPEN Member of OPEN
Community
82 Members
25 Guides authored
Past 24 Hours: 4
Past 7 Days: 41
Past 30 Days: 177
All Time: 34,251
