Super Nintendo 50/60 Hz Switchless Mod + LED Mod
  1. Super Nintendo 50/60 Hz Switchless Mod + LED Mod, Motherboard: step 1, image 1 of 1
    • Remove the two Phillips two 11.6mm screws that connect the front shield to the motherboard.
  2. Super Nintendo 50/60 Hz Switchless Mod + LED Mod: step 2, image 1 of 1
    • Lift the front shield straight up to remove it from the motherboard.
  3. Super Nintendo 50/60 Hz Switchless Mod + LED Mod: step 3, image 1 of 1
    • Remove the two silver 15.6 mm Phillips #2 screws on either side of the 62 pin connector.
  4. Super Nintendo 50/60 Hz Switchless Mod + LED Mod: step 4, image 1 of 1
    • Remove the 11.8 mm Phillips #2 screw near the rear of the SNES.
  5. Super Nintendo 50/60 Hz Switchless Mod + LED Mod: step 5, image 1 of 1
    • Lift the motherboard straight up to remove it.
  6. Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The Two Chips: step 6, image 1 of 1
    • The Two Chips that you need on your Super Nintendo
    • This mod only works on original Super Nintendo with 2 Chips, this mod doesn't work on the 1 Chip Snes.
  7. Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The Lockout Chip: step 7, image 1 of 2 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The Lockout Chip: step 7, image 2 of 2
    Tool used on this step:
    Desoldering Pump
    $3.99
    Buy
    • Remove the Lock Out chip (use the solder gun)
    • After removing the lock out chip there will probably be leftover of solder where the chip used to be so try to remove the soldier as good as you can
    • To remove the solder leftover, you can use the soldering iron and solder wick.
  8. Super Nintendo 50/60 Hz Switchless Mod + LED Mod, PPU 2: step 8, image 1 of 2 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, PPU 2: step 8, image 2 of 2
    • Lift up the PPU2 Pin 30 from the Motherboard
  9. Super Nintendo 50/60 Hz Switchless Mod + LED Mod, PPU 1: step 9, image 1 of 2 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, PPU 1: step 9, image 2 of 2
    • Now lift up Pin 24 on PPU 1
  10. Super Nintendo 50/60 Hz Switchless Mod + LED Mod, Wire Time: step 10, image 1 of 1
    • Wire the lifted pins (PPU 2 Pin 30 & PPU1 Pin 24) together
    • You need to use a Soldering Iron to wire the pins together
    • You can also use tape to hold the wires down to the motherboard
  11. Super Nintendo 50/60 Hz Switchless Mod + LED Mod, Program: step 11, image 1 of 1
  12. Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The Pins: step 12, image 1 of 3 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The Pins: step 12, image 2 of 3 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The Pins: step 12, image 3 of 3
    • Bend the pins outwards
    • Then clip the pins
    • Use double sided tape and put it on top of the CPU and put the Super CIC on top of the double sided tape.
  13. Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The Wires: step 13, image 1 of 3 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The Wires: step 13, image 2 of 3 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The Wires: step 13, image 3 of 3
    • Pic 1: Solder a wire from Super CIC Pin 12 to PPU1 Pin 24
    • Pic 2: Solder a wire from Super CIC Pin 14 to SWRAM Pin 64
    • Pic 3: Solder the 10k Ohm Resistor to the pin 8 (where the old CIC used to be) and to SWRAM Pin 33
  14. Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The Wires Part 2: step 14, image 1 of 3 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The Wires Part 2: step 14, image 2 of 3 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The Wires Part 2: step 14, image 3 of 3
    • Pic 1: Solder a Wire from Super CIC Pin 1 to 4 on the same chip.
    • Pic 2: Solder a wire from Super CIC Pin 1 to the CPU Pin 1
    • Pic 3: Solder a wire from Super CIC Pin 13 to the End Point of the Resistor
  15. Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The Wires Part 3: step 15, image 1 of 3 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The Wires Part 3: step 15, image 2 of 3 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The Wires Part 3: step 15, image 3 of 3
    • Pic 1: Sother a wire from Super CIC Pin 2 to S-CLK Pin 6
    • Pic 2: Sother a wire from Super CIC Pin 11 to Old CIC Pin 10
    • Pic 3: Sother a wire from Super CIC Pin 10 to Old CIC Pin 1
  16. Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The Wires Part 4: step 16, image 1 of 3 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The Wires Part 4: step 16, image 2 of 3 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The Wires Part 4: step 16, image 3 of 3
    • Pic 1: Solder a wire from Super CIC Pin 9 to Old CIC Pin 2
    • Pic 2: Solder a wire from Super CIC Pin 8 to Old CIC Pin 11
    • Pic 3: You've soldered most of the wires now, lets go to the LED Mod
  17. Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The LED Mod: step 17, image 1 of 3 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The LED Mod: step 17, image 2 of 3 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The LED Mod: step 17, image 3 of 3
    • Plug out the controller ports and solder out the LED Light.
    • When the solder points have been desoldered, you can use the tweezers to pull out the led light
    • Sother on the new LED Light with the middle pin on the left solder hole
    • Do Not sother the middle pin on the LED Light to the right solder hole as it will then be stuck in only one color!
  18. Super Nintendo 50/60 Hz Switchless Mod + LED Mod, Led Resistors: step 18, image 1 of 3 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, Led Resistors: step 18, image 2 of 3 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, Led Resistors: step 18, image 3 of 3
    • Solder 2 wires on the left and right pins on the led light, green wire on the left pin and red wire on the right pin.
    • After that you should put the wires into one heat shrink tube each, remember to heat the heat shrink tubes when its over the pins.
    • Then you have to solder the 2k Resistor to the red wire and the 220 ohm Resistor to the green wire.
    • Then the last thing you need to do is to solder a wire from Super CIC Pin 7 to Pin 14.
  19. Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The End: step 19, image 1 of 3 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The End: step 19, image 2 of 3 Super Nintendo 50/60 Hz Switchless Mod + LED Mod, The End: step 19, image 3 of 3
    • You're Now Done! You just need to put your Super Nintendo back together and then you have a Region Free Switchless Super Nintendo!
    • Green Light (PAL)
    • Red Light (NTSC) [For American and Japanese Games]
    • Orange Light (Auto)
These screenshots have been taken by 2 videoes, one from Global Garage and Chips y Bits on YouTube! I made this guide since its a little easier to read a guide with pictures like this instead of watching a 30 min video
Krisow
605 Reputation
2 Guides authored
3 Comments
Lo hice tal y como dice el tutorial y la snes se quedó con la pantalla negra.
dragonero - Reply
Is there some way to get a chip that is already programmed? I don’t have a plan on doing this a lot and the $100 is a bit much at the moment.
Brandon Vanoni - Reply
Will this same method be used for the PAL version if the console.
Adrees Sattar - Reply
Past 24 Hours: 6
Past 7 Days: 46
Past 30 Days: 223
All Time: 15,363
