Introduction
Go to step 1 ↓If the navigation buttons on your Summer LookOut Duo baby monitor are refusing to function or need cleaning, this guide is a step-by-step on how to access the navigation buttons for cleaning or repair.
Before proceeding, make sure the device is powered off and dry to avoid internal damage to the device or potential shock hazards. Some electrical components will need to be removed in order to get to the navigation buttons.
CHOKING HAZARD: This device contains small screws. If possible, use a magnetic mat or small container within eyesight to keep track of the screws to prevent possible ingestion or misplacement.
Tools
Flip the device over so the back is facing up.
Remove the 9 mm screw using a Phillips #1 screwdriver.
Lift the battery panel away from the device.
Using the Phillips #00 screwdriver, remove the four 7mm screws from each corner on the back of the handheld monitor.
Remove the casing from the back of the handheld monitor.
Using the angled tweezers, gently remove the plastic wire coupling connecting the speaker to the motherboard.
Gently remove the black foam padding from the back of the buttons.
Using your fingers, gently lift the navigation buttons from the front monitor casing.
