Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement
  1. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement, Top Floater Removal: step 1, image 1 of 1
    • Remove the black screw by rotating it counterclockwise.
    Ask FixBot
  2. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement: step 2, image 1 of 1
    • Hold the device in place and pull up on the floater.
    Ask FixBot
  3. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement: step 3, image 1 of 1
    • Remove the top floater.
    Ask FixBot
  4. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement, Battery: step 4, image 1 of 1
    • Turn the device upside-down.
    Ask FixBot
  5. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement: step 5, image 1 of 1
    • Press the push button in while sliding the planner towards the back of the device to remove the battery panel.
    Ask FixBot
  6. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement: step 6, image 1 of 1
    • A push tab holds the battery in.
    Ask FixBot
  7. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement: step 7, image 1 of 1
    • Push the tab in and pull the battery outward to remove it.
    Ask FixBot
  8. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement, Lower Panel: step 8, image 1 of 1
    • Remove the ten Phillips screws on the bottom of the device. Remove the bottom panel.
    Ask FixBot
  9. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement: step 9, image 1 of 1
    • Pull the panel forward.
    • You may need to use pry tools to aid in separating the panels.
    Ask FixBot
  10. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement, Safety Switch: step 10, image 1 of 1
    • Place the main body panel with the handle that holds the safety switch towards you. Pull the white tab of the right and pull towards you from the top of the safety switch.
    Ask FixBot
Benjamin J Farland
292 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 258
