Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement
  1. Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement, Top Floater Removal: step 1, image 1 of 1
    • Remove the black screw by rotating it counterclockwise.
    Ask FixBot
  2. Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement: step 2, image 1 of 1
    • Hold the device in place and pull up on the floater.
    Ask FixBot
  3. Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement: step 3, image 1 of 1
    • Remove the top floater.
    Ask FixBot
  4. Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement, Battery: step 4, image 1 of 1
    • Turn the device upside-down.
    Ask FixBot
  5. Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement: step 5, image 1 of 1
    • Press the push button in while sliding the planner towards the back of the device to remove the battery panel.
    Ask FixBot
  6. Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement: step 6, image 1 of 1
    • A push tab holds the battery in.
    Ask FixBot
  7. Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement: step 7, image 1 of 1
    • Push the tab in and pull the battery outward to remove it.
    Ask FixBot
  8. Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement, Lower Panel: step 8, image 1 of 1
    • Remove the ten Phillips screws on the bottom of the device. Remove the bottom panel.
    Ask FixBot
  9. Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement: step 9, image 1 of 1
    • Pull the panel forward.
    • You may need to use pry tools to aid in separating the panels.
    Ask FixBot
Luke Johnson
391 Reputation
4 Guides authored
1 Guide Comment
Is it possible to replace the electronics of the Sublue Watershark Mix?
Alenka Arambašić - Reply Share
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 29
All Time: 371
