Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement
  1. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Top Floater Removal: step 1, image 1 of 1
    • Remove the black screw by rotating it counterclockwise.
    Ask FixBot
  2. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: step 2, image 1 of 1
    • Hold the device in place and pull up on the floater.
    Ask FixBot
  3. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: step 3, image 1 of 1
    • Remove the top floater.
    Ask FixBot
  4. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Battery: step 4, image 1 of 1
    • Turn the device upside-down.
    Ask FixBot
  5. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: step 5, image 1 of 1
    • Press the push button in while sliding the planner towards the back of the device to remove the battery panel.
    Ask FixBot
  6. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: step 6, image 1 of 1
    • A push tab holds the battery in.
    Ask FixBot
  7. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: step 7, image 1 of 1
    • Push the tab in and pull the battery outward to remove it.
    Ask FixBot
  8. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Lower Panel: step 8, image 1 of 1
    • Remove the ten Phillips screws on the bottom of the device. Remove the bottom panel.
    Ask FixBot
  9. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: step 9, image 1 of 1
    • Pull the panel forward.
    • You may need to use pry tools to aid in separating the panels.
    Ask FixBot
  10. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Activation Buttons: step 10, image 1 of 1
    • There are two action buttons on each side of the main body.
    Ask FixBot
  11. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: step 11, image 1 of 1
    • Push on the top outer corner of each action button to pop them out of place.
    Ask FixBot
  12. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: step 12, image 1 of 1
    • After each action button is released, pull outward to remove.
    Ask FixBot
Benjamin J Farland
292 Reputation
2 Guides authored
3 Guide Comments
Mine have corroded, do you know where I can get x2 replacement activation buttons or just the circular discs??
AMW - Reply Share
Does anyone know where to find a replacement action button or what the metal disc is called on them
Mine have corroded
Ginger Wimberley - Reply Share
Yes, the magnets on the activation buttons corrode too fast and too easily. but they don't even list them for sale on their web page. You need to email or call Sublue support and request a cost including shipping. I'm still waiting for the email estimate.
Robert McRae - Reply Share
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 44
All Time: 519
