Storm Door Latch Replacement
    1. Storm Door Latch Replacement, Storm Door Latch: step 1, image 1 of 1
      • To start, unscrew your old storm door latch. This will require a standard Phillips head screw driver.
      Ask FixBot
    2. Storm Door Latch Replacement: step 2, image 1 of 1
      • Arrange your replacement parts in an orderly fashion. Assure you have all pieces from your replacement kit.
      Ask FixBot
    3. Storm Door Latch Replacement: step 3, image 1 of 1
      • Align your new handle and latch on either side of your door. Be certain that your screw holes are aligned on both sides.
      Ask FixBot
    4. Storm Door Latch Replacement: step 4, image 1 of 1
      • Partially secure screws to hold handles in position. Hand tighten the screws to hold pin, latch, and handle in the correct position for your door.
      Ask FixBot
    5. Storm Door Latch Replacement: step 5, image 1 of 1
      • Assure the pin is in the correct position. The pin should be in the center of your handle and latch. This will allow the button to be pressed and depressed.
      Ask FixBot
    6. Storm Door Latch Replacement: step 6, image 1 of 1
      • Finish securing screws once the pin is in the correct position. Ensure the button can be pressed.
      Ask FixBot
    7. Storm Door Latch Replacement: step 7, image 1 of 2 Storm Door Latch Replacement: step 7, image 2 of 2
      • Once assembled, press the button on the handle to make sure the handle and latch work effectively.
      Ask FixBot
NO319
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 93
All Time: 174
