ASUS Q536F SSD Replacement
    1. ASUS Q536F SSD Replacement, Back Panel: step 1, image 1 of 2 ASUS Q536F SSD Replacement, Back Panel: step 1, image 2 of 2
      • Remove ten 2 mm screws using a Phillips #0 screwdriver.
      • Remove the screw in the center using a T4 Torx screwdriver.
      • Use an iFixit opening tool to pry open the back panel.
      • It's normal to hear some cracking, but proceed with caution.
      Ask FixBot
    1. ASUS Q536F SSD Replacement, SSD: step 2, image 1 of 1
      • Remove the single 2 mm screw from the SSD with a Phillips #0 screwdriver.
      Ask FixBot
    2. ASUS Q536F SSD Replacement: step 3, image 1 of 1
      • Pull the SSD out of its slot.
      Ask FixBot
To reassemble your device, Follow these instructions in reverse order.
Adra Ledward
557 Reputation
5 Guides authored
Gateway, Team 88-8, Gonzalez Fall 2023 Member of Gateway, Team 88-8, Gonzalez Fall 2023
GCC-GONZALEZ-F23S88G8
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 33
All Time: 551
