Sony DVP-NS325 Power Cable Replacement
  1. Sony DVP-NS325 Power Cable Replacement, Outer Case: step 1, image 1 of 3 Sony DVP-NS325 Power Cable Replacement, Outer Case: step 1, image 2 of 3 Sony DVP-NS325 Power Cable Replacement, Outer Case: step 1, image 3 of 3
    • Use a Phillips screwdriver to unscrew the five screws.
  2. Sony DVP-NS325 Power Cable Replacement: step 2, image 1 of 3 Sony DVP-NS325 Power Cable Replacement: step 2, image 2 of 3 Sony DVP-NS325 Power Cable Replacement: step 2, image 3 of 3
    • Use the Philips screwdriver to remove the screws located on the sides and the back.
    • Not shown are the right side screw and the middle screw.
  3. Sony DVP-NS325 Power Cable Replacement: step 3, image 1 of 1
    • Use a spudger to separate the case from the chassis.
    • Remove the case.
  4. Sony DVP-NS325 Power Cable Replacement, Power Cable: step 4, image 1 of 2 Sony DVP-NS325 Power Cable Replacement, Power Cable: step 4, image 2 of 2
    • Unscrew all screws using a Phillips screwdriver removing the outer case to access the power cable.
  5. Sony DVP-NS325 Power Cable Replacement: step 5, image 1 of 2 Sony DVP-NS325 Power Cable Replacement: step 5, image 2 of 2
    • Using a finger, press down on the clip to remove the connector for the cable.
  6. Sony DVP-NS325 Power Cable Replacement: step 6, image 1 of 1
    • Using two fingers, press in both the top and bottom clips to release the holder for the power cable to remove the cable completely.
  7. Sony DVP-NS325 Power Cable Replacement: step 7, image 1 of 1
    • Pull the cable out of the case to fully replace the cable.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 18
All Time: 226
