iRobot Roomba 890 IR Sensor Replacement
Views: 2K
View statistics:
Past 24 Hours:
9
Past 7 Days:
29
Past 30 Days:
104
All Time:
1,975
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide addresses the removal of a malfunctioning or broken Roomba IR sensor. Roomba IR sensors measure how close a Roomba is to a wall or object and create a map of the cleaning area. The sensor can become defective when obscured with dust or lint. You will remove the exterior plates and casings of the Roomba to reach the motherboard where the sensor is attached. To reassemble the Roomba after the replacement, follow the steps in reverse.
Tools
    1. iRobot Roomba 890 IR Sensor Replacement, IR sensor: step 1, image 1 of 1
      • Use a Phillips #2 screwdriver to remove the two 11 mm screws.
      • Remove the battery cover.
      Ask FixBot
    2. iRobot Roomba 890 IR Sensor Replacement: step 2, image 1 of 2 iRobot Roomba 890 IR Sensor Replacement: step 2, image 2 of 2
      • Pull directly up on the grey pull-tabs to remove the battery.
      Ask FixBot
    3. iRobot Roomba 890 IR Sensor Replacement: step 3, image 1 of 1
      • Use a Phillips #2 screwdriver to remove the one 7.7 mm screw.
      • Remove the yellow brush head.
      Ask FixBot
    4. iRobot Roomba 890 IR Sensor Replacement: step 4, image 1 of 3 iRobot Roomba 890 IR Sensor Replacement: step 4, image 2 of 3 iRobot Roomba 890 IR Sensor Replacement: step 4, image 3 of 3
      • Use a Phillips #2 screwdriver to unscrew the two 11 mm screws.
      • Lift the baseplate up and off.
      Ask FixBot
    5. iRobot Roomba 890 IR Sensor Replacement: step 5, image 1 of 2 iRobot Roomba 890 IR Sensor Replacement: step 5, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the ten 9.3 mm screws.
      • Remove the bumper retainer ring.
      Ask FixBot
    6. iRobot Roomba 890 IR Sensor Replacement: step 6, image 1 of 2 iRobot Roomba 890 IR Sensor Replacement: step 6, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the two 7.5 mm screws holding the IR sensor in place.
      Ask FixBot
    7. iRobot Roomba 890 IR Sensor Replacement: step 7, image 1 of 2 iRobot Roomba 890 IR Sensor Replacement: step 7, image 2 of 2
      • Use an iFixit opening tool to remove the outer plastic covering from the top of the Roomba.
      Ask FixBot
    8. iRobot Roomba 890 IR Sensor Replacement: step 8, image 1 of 3 iRobot Roomba 890 IR Sensor Replacement: step 8, image 2 of 3 iRobot Roomba 890 IR Sensor Replacement: step 8, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the two 9.5 mm handlebar screws; then remove the handle.
      • Use a Phillips #1 screwdriver to remove the fourteen 9.5 mm top plate screws.
      • Lift off the top plate.
      Ask FixBot
    9. iRobot Roomba 890 IR Sensor Replacement: step 9, image 1 of 3 iRobot Roomba 890 IR Sensor Replacement: step 9, image 2 of 3 iRobot Roomba 890 IR Sensor Replacement: step 9, image 3 of 3
      Tool used on this step:
      $3.99
      Buy
      • Use a pair of angled tweezers to firmly grip the IR sensor plug, and pull it directly backwards to release it from the motherboard.
      Ask FixBot
2 other people completed this guide.
Caeden Foxhoven
367 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 29
Past 30 Days: 104
All Time: 1,975
