Acer Chromebook CP5-471-C0EX Battery Replacement
    1. Acer Chromebook CP5-471-C0EX Battery Replacement, Back Cover: step 1, image 1 of 2 Acer Chromebook CP5-471-C0EX Battery Replacement, Back Cover: step 1, image 2 of 2
      • Turn off the laptop before starting.
      • Flip the laptop over so the model stickers face the ceiling.
      Ask FixBot
    2. Acer Chromebook CP5-471-C0EX Battery Replacement: step 2, image 1 of 3 Acer Chromebook CP5-471-C0EX Battery Replacement: step 2, image 2 of 3 Acer Chromebook CP5-471-C0EX Battery Replacement: step 2, image 3 of 3
      • Remove twelve 7 mm screws from the back of the laptop using a Phillips #1 screwdriver.
      Ask FixBot
    3. Acer Chromebook CP5-471-C0EX Battery Replacement: step 3, image 1 of 2 Acer Chromebook CP5-471-C0EX Battery Replacement: step 3, image 2 of 2
      • Use a Jimmy to pry apart the bottom of the case from the laptop.
      • Be careful not to warp or crack the case.
      Ask FixBot
    1. Acer Chromebook CP5-471-C0EX Battery Replacement, Battery: step 4, image 1 of 2 Acer Chromebook CP5-471-C0EX Battery Replacement, Battery: step 4, image 2 of 2
      • Carefully detach the ribbon cable connecting the battery and the motherboard.
      Ask FixBot
    2. Acer Chromebook CP5-471-C0EX Battery Replacement: step 5, image 1 of 1
      • Use your hands to lift the battery out of the device.
      Ask FixBot
2 other people completed this guide.
Naomi Salas
244 Reputation
2 Guides authored
Gateway, Team 1-1, Saknee Spring 2022 Member of Gateway, Team 1-1, Saknee Spring 2022
GCC-SAKNEE-S22S1G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 605
