Installing Starbucks Barista Pump
  1. Installing Starbucks Barista Pump, Pump: step 1, image 1 of 3 Installing Starbucks Barista Pump, Pump: step 1, image 2 of 3 Installing Starbucks Barista Pump, Pump: step 1, image 3 of 3
    • First remove all six screws on the back panel.
    • Remove the back panel, then set it aside.
    • Remove the two screws holding the bottom panel in place.
    • Remove the bottom panel, then set it aside.
  2. Installing Starbucks Barista Pump: step 2, image 1 of 3 Installing Starbucks Barista Pump: step 2, image 2 of 3 Installing Starbucks Barista Pump: step 2, image 3 of 3
    • Pull the drip tray out, then set it aside.
    • Turn the brew unit clockwise to unscrew.
    • Pull the tube that goes into water reservoir out.
    • Slide the water reservoir out through the front of the barista to remove it.
    • Remove the top tray from the backside.
  3. Installing Starbucks Barista Pump: step 3, image 1 of 3 Installing Starbucks Barista Pump: step 3, image 2 of 3 Installing Starbucks Barista Pump: step 3, image 3 of 3
    • Use an adjustable wrench to unscrew the connection tube between the pump and the boiler.
    • Pull off both tubes connecting on each side of the pump.
    • Remove the 3 electrical connectors from the pump.
  4. Installing Starbucks Barista Pump: step 4, image 1 of 3 Installing Starbucks Barista Pump: step 4, image 2 of 3 Installing Starbucks Barista Pump: step 4, image 3 of 3
    • Unscrew the two mounting bolts.
    • Remove the pump unit from the Barista.
    • Pull off the yellow end of the pump and unscrew T-shaped end.
    • See the links section of the device page for where to purchase a new pump.
Alex
503 Reputation
1 Guide authored
Cal Poly, Team 4-42, Regan Winter 2011 Member of Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 84
All Time: 36,560
