Introduction
The pump is used to take the water from the reservoir to the portafilter and steam wand.
First remove all six screws on the back panel.
Remove the back panel, then set it aside.
Remove the two screws holding the bottom panel in place.
Remove the bottom panel, then set it aside.
17 other people completed this guide.
22 Guide Comments
My son and I successfully replaced the pump, but it didn't go quite as easily as I'd thought. We could not get the hose that connects the boiler to the pump off. Thankfully, my clever son realized we could turn the portion of the pump that screws into the t-end to get the old pump off and new one on.....tricky, but doable. The new pump is a bit noisier than the last, but she pulls beautiful shots. Thanks so much for this guide!
I put in a new pump and it still doesn’t work. I hear it him but can’t get it to pull water. I’ve tried the water in the line thing. How is the best way to prime it? Maybe that’s it?
Wendy
Open the steam valve, so there is no back pressure inside the boiler preventing the pump from pulling water.
Thanks for this tip.
I had the same problem, could not get the tefflon tube out of the brass T/OPV.
Rotated the pump off the T/OPV.
