Stapler Spring Replacement
  1. Stapler Spring Replacement, Spring: step 1, image 1 of 2 Stapler Spring Replacement, Spring: step 1, image 2 of 2
    • Open the stapler by gripping the handle to access the spring.
  2. Stapler Spring Replacement: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Pry open the hook found on the pusher using the tweezers.
    • Hold the handle firmly to prevent the stapler from snapping back.
  3. Stapler Spring Replacement: step 3, image 1 of 1
    • Unhook the end of the spring from the pusher.
    • Pinch the spring firmly between your fingers to keep it from snapping back.
  4. Stapler Spring Replacement: step 4, image 1 of 2 Stapler Spring Replacement: step 4, image 2 of 2
    • Unhook the other end of the spring from the inside of the handle.
    • The spring should be unthreaded from the holes on the handle's metal part.
  5. Stapler Spring Replacement: step 5, image 1 of 2 Stapler Spring Replacement: step 5, image 2 of 2
    • Press down on the metal part inside the handle with your thumbs until it will not go down anymore.
  6. Stapler Spring Replacement: step 6, image 1 of 2 Stapler Spring Replacement: step 6, image 2 of 2
    • Push the hammer, the rectangular piece, up and away from the metal part.
  7. Stapler Spring Replacement: step 7, image 1 of 1
    • Release the metal part inside the handle so it comes away from the hammer.
    • Keep hold of the metal part to keep it from snapping closed.
  8. Stapler Spring Replacement: step 8, image 1 of 1
    • Hook one end of the new spring onto the pusher's hook.
  9. Stapler Spring Replacement: step 9, image 1 of 1
    • Clamp the pusher's hook closed using your thumb.
  10. Stapler Spring Replacement: step 10, image 1 of 1
    • Thread the other end of the new spring through the top rectangular hole toward the back.
  11. Stapler Spring Replacement: step 11, image 1 of 1
    • Thread the new spring through the bottom hole, bringing the end of spring toward you.
    • The spring should create a loop when done threading.
  12. Stapler Spring Replacement: step 12, image 1 of 2 Stapler Spring Replacement: step 12, image 2 of 2
    • Hook the new spring to the hook on the inside of the handle's metal part.
  13. Stapler Spring Replacement: step 13, image 1 of 2 Stapler Spring Replacement: step 13, image 2 of 2
    • Press the metal part down with your thumbs until it aligns with the hammer's hole.
  14. Stapler Spring Replacement: step 14, image 1 of 2 Stapler Spring Replacement: step 14, image 2 of 2
    • Reattach the hammer back onto the metal part.
  15. Stapler Spring Replacement: step 15, image 1 of 2 Stapler Spring Replacement: step 15, image 2 of 2
    • Close the handle until it clicks back into place.
    • Be careful not to staple your fingers when closing the stapler.
12 other people completed this guide.
13 Guide Comments
Just what I needed. Thank you! Super clear
Daniela Labra - Reply Share
Can I replace the black rubber piece that goes on my swingling desk top stapler 70 sheet it came off and my dog chewed it up.
Edith Corkell - Reply Share
fron this sale ski o donde venden los repuestos de esta engrapadora en Venezuela gran caracas
Romulo - Share
Wie funktioniert das für große Klammermaschinen wie dieser hier?
Matthias Jünger - Reply Share
Where do I obtain a replacement spring for this stapler?
John Drake - Reply Share
Past 24 Hours: 166
Past 7 Days: 1,217
Past 30 Days: 5,589
All Time: 290,272
