Stapler Maintenance
  1. Stapler Maintenance, Open & Identify: step 1, image 1 of 2 Stapler Maintenance, Open & Identify: step 1, image 2 of 2
    • Be careful while handling staples or any sharp object in general.
    • Grab the base of the stabler, and pull the hammer until the stapler opens, revealing the carrier, pusher, and spring.
    • Identify the staple type by looking on the bottom of the carrier. If the staple type is not on the carrier, look under the base.
  2. Stapler Maintenance, Insert Staples: step 2, image 1 of 2 Stapler Maintenance, Insert Staples: step 2, image 2 of 2
    • Get a cluster of staples and carefully place it in the carrier.
    • Make sure there is enough room for the pusher to contact the staples.
    • Close the stapler by clearing your hand from under the crimp area and pushing the hammer down until a clicking sound is heard.
  3. Stapler Maintenance: step 3, image 1 of 1
    • Don’t staple your hand, or anyone else for that matter.
    • Congratulations! You have successfully replaced staples in your stapler.
9 other people completed this guide.
Sequoia Equities
261 Reputation
1 Guide authored
2 Guide Comments
Wnen I tried to load the staples, the spring came loose. But I do not know where to reconnect it and have a loose short plastic rod!
Brian Gray - Reply Share
@ cookie clicker When I attempted to load the staples, the spring became detached. However, I'm unsure where to reattach it, and I now have a loose, short plastic rod.
Nadia Eira - Reply Share
Past 24 Hours: 87
Past 7 Days: 435
Past 30 Days: 1,604
All Time: 48,547
