Community-Contributed Guide
Introduction
Go to step 1 ↓Does your Soundboks Go suddenly sound rattling or distorted during bass-heavy songs? - your woofer may be the troublemaker.
Here is a guide on how to replace it, have fun!
Turn off your speaker and unplug the DC barrel connector or simply remove the battery from the slot-in.
Unscrew the 12x T20 screws fastening the front grill to the cabinet
Pop the grill off, resting thumbs on the rubber and pull upwards
Do not unconnect cables, simply rest the front baffle like shown
Carefully cut the zip tie fixing the woofer cable to the cabinet.
Unplug 2 x Molex cable for speakers (Red + White connectors).
The front baffle is now free, and you can put it to the side.
Place the front baffle with the grill resting on a surface.
Remove the 8x screws fastening the woofer to the front grill.
Separate the woofer and tweeter cables. You can simply pull the cables apart and the foam will break.
Remove the woofer by pulling upwards.
Install the 8x screws fastening the new woofer to the front grill, making sure it's seated in the correct orientation
Twist the woofer and tweeter cables together
Apply the new foam to the woofer and tweeter cables, following the direction of the twist
Plug the woofer connector back into the PCBA
Fix the cable with a new zip tie in the original placement and orientation
Reinstall the grill, making sure the rubber bumper sits correctly and isn't squeezed, and fasten the 12x screws
Woah, you made it through the disassembly. Now reassemble your device by following these instructions in reverse order.
We recommend to test the repair by playing a bass-heavy song - if anything is rattling, you may need to tighten a screw somewhere.
