Community-Contributed Guide
Introduction
Go to step 1 ↓Does your speaker sound like being underwater?
Probably the tweeter is failing. Here is an easy guide on how to replace it.
Turn off your speaker and unplug the DC barrel connector / remove the battery from the slot-in
Unscrew 12 screws - using Torx TX20.
Pop the grill off, resting thumbs on the rubber and pull upwards.
Do not unconnect cables, simply rest the front baffle like shown.
Carefully cut the zip tie fixing the tweeter cable to the cabinet
Unplug 2 x Molex cable for speakers (Red + White connectors).
The front baffle is now free, and you can put it to the side.
Place the front baffle with the grill resting on a surface.
Remove the 6x T20 screws fastening the tweeter horn to the front grill
Separate the woofer and tweeter cables. You can simply pull the cables apart and the foam will break.
Remove the tweeter and tweeter horn by pulling upwards.
Install the 6x screws fastening the new tweeter horn to the front grill, making sure it's seated in the correct orientation.
Twist the woofer and tweeter cables together.
Apply the new foam to the woofer and tweeter cables, following the direction of the twist.
Plug the tweeter connector back into the port on the PCBA
Fix the cable with a new zip tie in the original placement and orientation
Reinstall the grill, making sure the rubber bumper sits correctly and isn't squeezed, and fasten the 12x screws
That's it, you done the hard part.
