Up to 20% off select tools
Soundboks Go PCBA Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
94
All Time:
99
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Sometimes your Soundboks Go just isn't feeling it. Won't power on, won't hold a Bluetooth connection, that sort of thing.
The usual suspect is the PCBA. It's the electronics board, the brain and heart of the whole thing, and sometimes it needs replacing.
Note:
Every PCBA is pre-configured with your speaker's serial number and Team-ID. Order it by contacting SOUNDBOKS customer service.
    1. Soundboks Go PCBA Replacement, Getting Ready: step 1, image 1 of 2 Soundboks Go PCBA Replacement, Getting Ready: step 1, image 2 of 2
      • Turn off your speaker by disconnecting the battery.
      • Do not use power tools in this repair - it may rip the plastics and damage product.
      • ESD / Static electricity: Great for balloon tricks, terrible for PCBAs. Ground yourself or discharge before handling.
      Ask FixBot
    2. Soundboks Go PCBA Replacement, Open Front Baffle: step 2, image 1 of 3 Soundboks Go PCBA Replacement, Open Front Baffle: step 2, image 2 of 3 Soundboks Go PCBA Replacement, Open Front Baffle: step 2, image 3 of 3
      • Unscrew 12 screws - using Torx TX20.
      • Pop the grill off, resting thumbs on the rubber and pull upwards.
      • Do not unconnect cables, simply rest the front baffle like shown.
      Ask FixBot
    3. Soundboks Go PCBA Replacement, Disconnect Front Baffle: step 3, image 1 of 2 Soundboks Go PCBA Replacement, Disconnect Front Baffle: step 3, image 2 of 2
      • Cut zip-tie as indicated.
      • Unplug 2 x Molex cable for speakers (Red + White connectors).
      • The front baffle is now free, and you can put it to the side.
      Ask FixBot
    4. Soundboks Go PCBA Replacement, Remove the Volume Knob: step 4, image 1 of 3 Soundboks Go PCBA Replacement, Remove the Volume Knob: step 4, image 2 of 3 Soundboks Go PCBA Replacement, Remove the Volume Knob: step 4, image 3 of 3
      • Loosen the set screw in the volume knob with the 2.5 mm hex key until the knob lifts off the encoder.
      Ask FixBot
    5. Soundboks Go PCBA Replacement, Detach the Volume Knob Encoder: step 5, image 1 of 3 Soundboks Go PCBA Replacement, Detach the Volume Knob Encoder: step 5, image 2 of 3 Soundboks Go PCBA Replacement, Detach the Volume Knob Encoder: step 5, image 3 of 3
      • Remove the rubber gasket.
      • You may need to poke into the rubber to get it off.
      • Unscrew the fastening nut, with the 10 mm deep socket.
      Ask FixBot
    6. Soundboks Go PCBA Replacement, Remove the encoder stabilizer: step 6, image 1 of 3 Soundboks Go PCBA Replacement, Remove the encoder stabilizer: step 6, image 2 of 3 Soundboks Go PCBA Replacement, Remove the encoder stabilizer: step 6, image 3 of 3
      • Use tweezers to lift out the tiny encoder stabilizer (small black plastic piece).
      • Keep it for reassembly
      Ask FixBot
    7. Soundboks Go PCBA Replacement, Remove the PCBA: step 7, image 1 of 3 Soundboks Go PCBA Replacement, Remove the PCBA: step 7, image 2 of 3 Soundboks Go PCBA Replacement, Remove the PCBA: step 7, image 3 of 3
      • Remove DC Power Molex.
      • Unscrew 4 PCBA screws - using a 2.5mm Hex.
      • Do not unplug the SKAA Antenna at this step (red circle)
      • Lift the PCBA a few mm (green arrow). Then pull the PCBA sideways (blue arrow) - to let the Aux connector gently slide out - and hold the PCBA in your hand.
      Ask FixBot
    8. Soundboks Go PCBA Replacement, Disconnect the SKAA Antenna: step 8, image 1 of 2 Soundboks Go PCBA Replacement, Disconnect the SKAA Antenna: step 8, image 2 of 2
      • Hold the PCBA in your hand
      • Cut the zip-tie and unplug the SKAA (TEAM-UP) Antenna cable.
      • Make the cut on the back, to avoid cable damage
      • The glue easily pops off, otherwise help it along with a small cut.
      • Pull the antenna connector carefully
      Ask FixBot
    9. Soundboks Go PCBA Replacement, Remove the encoder washer: step 9, image 1 of 2 Soundboks Go PCBA Replacement, Remove the encoder washer: step 9, image 2 of 2
      • Lift out the old PCBA.
      • Remove the washer from around the volume encoder and set it aside for reuse.
      • The washer is glued, but it comes off with a little force.
      Ask FixBot
    10. Soundboks Go PCBA Replacement, Prep the New PCBA: step 10, image 1 of 3 Soundboks Go PCBA Replacement, Prep the New PCBA: step 10, image 2 of 3 Soundboks Go PCBA Replacement, Prep the New PCBA: step 10, image 3 of 3
      • Place the washer from the old PCBA onto the new one.
      • Place the foam ring around the AUX connector on the new PCBA.
      • Plug the SKAA antenna connector into the new PCBA (notice a small click) and fix it with a new zip tie in the original orientation; cut the excess zip-tie.
      • There is no need to add new glue, the zip-tie is adequate.
      Ask FixBot
    11. Soundboks Go PCBA Replacement, Mount the New PCBA: step 11, image 1 of 3 Soundboks Go PCBA Replacement, Mount the New PCBA: step 11, image 2 of 3 Soundboks Go PCBA Replacement, Mount the New PCBA: step 11, image 3 of 3
      • Slide the AUX connector into the cabinet hole to seat the PCBA in the correct orientation
      • Be careful when re-inserting the PCBA, it will fit in nicely when you find the right placement.
      • Install the 4x screws fastening the PCBA to the cabinet, don't overtighten, it'll strip the plastic
      • While screwing: Apply sustained pressure to the PCBA to compress the foam around the aux connector so it sits in place (red arrow).
      • Plug the Woofer, Tweeter, and Power connectors back into the PCBA.
      Ask FixBot
Congrats, all the hard work is done. To reassemble your device, follow these instructions in reverse order.
SOUNDBOKS Tech Crew
42 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 94
All Time: 99
