Up to 20% off select tools
Soundboks 4 Woofer Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
118
All Time:
185
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Does your Soundboks 4 suddenly sound rattling or distorted during bass-heavy songs? - your woofer may be the troublemaker.
The Soundboks 4 contains two identical 10" woofers, each are taking on a different job - but the parts are identical. Take a close listen, and identify the faulty woofer - the repair is easy enough.
Have fun!
    1. Soundboks 4 Woofer Replacement, Getting Ready: step 1, image 1 of 2 Soundboks 4 Woofer Replacement, Getting Ready: step 1, image 2 of 2
      • Turn off your speaker by disconnecting the battery
      Ask FixBot
    2. Soundboks 4 Woofer Replacement, Grille Removal: step 2, image 1 of 3 Soundboks 4 Woofer Replacement, Grille Removal: step 2, image 2 of 3 Soundboks 4 Woofer Replacement, Grille Removal: step 2, image 3 of 3
      • Put the speaker flat down on its back
      • Use the hook in each corner and pull lightly upwards
      • Don't pull up the grille more than a few cm before all corners are loose
      • The grille is now removed by hand
      Ask FixBot
    3. Soundboks 4 Woofer Replacement, Unscrew Woofer: step 3, image 1 of 3 Soundboks 4 Woofer Replacement, Unscrew Woofer: step 3, image 2 of 3 Soundboks 4 Woofer Replacement, Unscrew Woofer: step 3, image 3 of 3
      • Use the Hex tool to unscrew all 8 screws. Follow the indicated order
      • If the woofer sticks, pry up with a small flathead tool, or grip it firmly by the edges and pull.
      • The order for unscrewing the woofer, should be followed to screw it back
      • Careful removing the woofer as there are 2 cables connected to it
      Ask FixBot
    4. Soundboks 4 Woofer Replacement, Woofer Cable: step 4, image 1 of 3 Soundboks 4 Woofer Replacement, Woofer Cable: step 4, image 2 of 3 Soundboks 4 Woofer Replacement, Woofer Cable: step 4, image 3 of 3
      • Gently press the tab on the cable connector and pull to remove the cables from the woofer
      • Be aware the the connectors have different widths
      Ask FixBot
! Remember to follow the screw order in reverse - to avoid damaging your woofer !
SOUNDBOKS Tech Crew
42 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 118
All Time: 185
