Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓Does your speaker sound like being underwater?
Probably the tweeter is failing. Here is an easy guide on how to replace it.
Put the speaker flat down on its back
Use the hook in each corner and pull lightly upwards
The grille is now removed by hand
Unscrew the 5 screws with a screwdriver or a drill (3mm hex bit) and gently remove the tweeter
Gently press the tab on the cable connector and pull to remove the cables from the tweeter
Attach the cables to the new Tweeter, make sure to click them in and use the correct one for each clip size
You can follow the previous steps to put it back and get it running!
