Sony Xplod CDX-MP30 Main Panels Replacement
  1. Sony Xplod CDX-MP30 Main Panels Replacement, Front Panel: step 1, image 1 of 3 Sony Xplod CDX-MP30 Main Panels Replacement, Front Panel: step 1, image 2 of 3 Sony Xplod CDX-MP30 Main Panels Replacement, Front Panel: step 1, image 3 of 3
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 Main Panels Replacement, Main Panels: step 2, image 1 of 2 Sony Xplod CDX-MP30 Main Panels Replacement, Main Panels: step 2, image 2 of 2
    Tool used on this step:
    Phillips #0 Screwdriver
    $5.49
    Buy
  3. Sony Xplod CDX-MP30 Main Panels Replacement: step 3, image 1 of 3 Sony Xplod CDX-MP30 Main Panels Replacement: step 3, image 2 of 3 Sony Xplod CDX-MP30 Main Panels Replacement: step 3, image 3 of 3
    Phillips #1 Screwdriver
    $5.49
    Buy
    • Using the Phillips #1 Screwdriver, unscrew the 2 thick screws (length - 7.69mm) located on both sides of the stereo.
    • Remove side-metal plates gently.
    • Use the Heavy-duty Spudger, insert the flat end under each of the black flaps indicated in the picture. Use leverage to pry and pop them loose.
  4. Sony Xplod CDX-MP30 Main Panels Replacement: step 4, image 1 of 1
    • Remove the black front plate of the stereo.
  5. Sony Xplod CDX-MP30 Main Panels Replacement: step 5, image 1 of 2 Sony Xplod CDX-MP30 Main Panels Replacement: step 5, image 2 of 2
    $5.49
    Buy
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (height - 7.47mm) on the top of the stereo.
    • Lift off the top plate.
  6. Sony Xplod CDX-MP30 Main Panels Replacement: step 6, image 1 of 3 Sony Xplod CDX-MP30 Main Panels Replacement: step 6, image 2 of 3 Sony Xplod CDX-MP30 Main Panels Replacement: step 6, image 3 of 3
    $5.49
    Buy
    • Using the Phillips #0 Screwdriver, unscrew the 8 gold screws (length - 9.26mm), located on the back side of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 2 black screws (length - 13.27mm), also located on the back of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (length - 9.3mm), located on the bottom of a hole as noted in pictures (2) and (3).
  7. Sony Xplod CDX-MP30 Main Panels Replacement: step 7, image 1 of 3 Sony Xplod CDX-MP30 Main Panels Replacement: step 7, image 2 of 3 Sony Xplod CDX-MP30 Main Panels Replacement: step 7, image 3 of 3
    • Carefully pull the fuse out of the back of the stereo.
  8. Sony Xplod CDX-MP30 Main Panels Replacement: step 8, image 1 of 2 Sony Xplod CDX-MP30 Main Panels Replacement: step 8, image 2 of 2
    • Firmly grip the body of the stereo and pull off the silver back plate.
  9. Sony Xplod CDX-MP30 Main Panels Replacement: step 9, image 1 of 1
    $5.49
    Buy
  10. Sony Xplod CDX-MP30 Main Panels Replacement: step 10, image 1 of 2 Sony Xplod CDX-MP30 Main Panels Replacement: step 10, image 2 of 2
    $5.49
    Buy
    • Using the Phillips #0 Screwdriver, unscrew the 2 gold screws (length - 7.34mm) found on both sides of the stereo.
  11. Sony Xplod CDX-MP30 Main Panels Replacement: step 11, image 1 of 3 Sony Xplod CDX-MP30 Main Panels Replacement: step 11, image 2 of 3 Sony Xplod CDX-MP30 Main Panels Replacement: step 11, image 3 of 3
    • Grip the top portion of the stereo, where the CD-Drive is located, and gently pull up to release it, but you will not be able to lift it all the way out.
    • Grab the two tabs located near the back of the stereo, and gently pull the CD-drive front the rest of the device.
Chao Chen
79 Reputation
5 Guides authored
Cal Poly, Team 5-35, Amido Fall 2011 Member of Cal Poly, Team 5-35, Amido Fall 2011
CPSU-AMIDO-F11S5G35
4 Members
8 Guides authored
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 9
All Time: 3,606
