Introduction
Make sure you can explore the Xplod very well.
Press down the release button on the bottom left corner of the face plate.
Then remove the face plate carefully.
Unscrew the four (length - 11.11mm) phillips-head screws on the front screen
Use two fingers to create a small gap in the top of the faceplate, as indicated in the picture.
Insert the flat end of the black Spudger into the opening you created.
Slide it to the right carefully, until you feel the screen pop off.
Make sure you keep the face of the screen pointed down as you carefully lift off the freed black portion of the screen - as shown in the picture.
Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen.
Once the LCD screen is removed, you have unrestricted access to the front screen motherboard. To remove the LCD, please refer to the iFixit soldering guide
