Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement
  1. Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement, Rear camera & Earpiece & Front camera: step 1, image 1 of 2 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement, Rear camera & Earpiece & Front camera: step 1, image 2 of 2
    • Power off and remove SIM card tray.
  2. Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: step 2, image 1 of 3 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: step 2, image 2 of 3 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: step 2, image 3 of 3
    • Heat up the back cover to soften the adhesive.
    • Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
    • Remove back cover.
  3. Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: step 3, image 1 of 2 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: step 3, image 2 of 2
    • Twist off 10 Phillips screws all.
    • Loosen NFC clip and flashlight clip.
  4. Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: step 4, image 1 of 3 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: step 4, image 2 of 3 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: step 4, image 3 of 3
    • Remove the plastic bracket.
    • Pry up and remove back frame.
  5. Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: step 5, image 1 of 3 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: step 5, image 2 of 3 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: step 5, image 3 of 3
    • Remove front camera.
  6. Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: step 6, image 1 of 2 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: step 6, image 2 of 2
    • Remove earpiece.
  7. Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: step 7, image 1 of 3 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: step 7, image 2 of 3 Sony Xperia Z5C Rear camera & Earpiece & Front camera Replacement: step 7, image 3 of 3
    • Remove rear camera.
5 other people completed this guide.
Witrigs
69,493 Reputation
378 Guides authored
2 Comments
where i can get the plastic bracket? my plastic bracket is broke
Ranon Kusuma - Reply
Step 4: the flash/lamp is lighly glued to the back frame. It must be delicately unglued off before the frame can be removed.
Frédéric Leroy - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 4,774
