Sony Xperia Z5C Charging port flex Replacement
  1. Sony Xperia Z5C Charging port flex Replacement, Charging port flex: step 1, image 1 of 2 Sony Xperia Z5C Charging port flex Replacement, Charging port flex: step 1, image 2 of 2
    • Power off and remove SIM card tray.
  2. Sony Xperia Z5C Charging port flex Replacement: step 2, image 1 of 3 Sony Xperia Z5C Charging port flex Replacement: step 2, image 2 of 3 Sony Xperia Z5C Charging port flex Replacement: step 2, image 3 of 3
    • Heat up the back cover to soften the adhesive.
    • Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
    • Remove back cover.
  3. Sony Xperia Z5C Charging port flex Replacement: step 3, image 1 of 2 Sony Xperia Z5C Charging port flex Replacement: step 3, image 2 of 2
    • Twist off 10 Phillips screws all.
    • Loosen NFC clip and flashlight clip.
  4. Sony Xperia Z5C Charging port flex Replacement: step 4, image 1 of 3 Sony Xperia Z5C Charging port flex Replacement: step 4, image 2 of 3 Sony Xperia Z5C Charging port flex Replacement: step 4, image 3 of 3
    • Remove the plastic bracket.
    • Pry up and remove back frame.
  5. Sony Xperia Z5C Charging port flex Replacement: step 5, image 1 of 3 Sony Xperia Z5C Charging port flex Replacement: step 5, image 2 of 3 Sony Xperia Z5C Charging port flex Replacement: step 5, image 3 of 3
    • Remove front camera.
  6. Sony Xperia Z5C Charging port flex Replacement: step 6, image 1 of 3 Sony Xperia Z5C Charging port flex Replacement: step 6, image 2 of 3 Sony Xperia Z5C Charging port flex Replacement: step 6, image 3 of 3
    • Remove rear camera.
  7. Sony Xperia Z5C Charging port flex Replacement: step 7, image 1 of 3 Sony Xperia Z5C Charging port flex Replacement: step 7, image 2 of 3 Sony Xperia Z5C Charging port flex Replacement: step 7, image 3 of 3
    • Remove loudspeaker.
  8. Sony Xperia Z5C Charging port flex Replacement: step 8, image 1 of 3 Sony Xperia Z5C Charging port flex Replacement: step 8, image 2 of 3 Sony Xperia Z5C Charging port flex Replacement: step 8, image 3 of 3
    • Release charging port connector.
    • Remove plastic protective bar.
    • Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
  9. Sony Xperia Z5C Charging port flex Replacement: step 9, image 1 of 1
    • Remove charging port flex.
Witrigs
69,496 Reputation
378 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 22
All Time: 9,659
