Introduction
This guide provides step by step instructions on how to properly replace the screen of the Sony Xperia Z5 Compact.
Heat up the back cover to soften the adhesive.
Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
Remove back cover.
Release charging port connector.
Remove plastic protective bar.
Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
Remove the motherboard/battery assembly.
Using a spudger, release the battery connector from the motherboard.
Using a suction cup, create a space between the screen and the phone.
Using an opening tool, pry the LCD screen up.
