Sony Xperia Z2 Rear / Battery Cover Replacement
Video Overview
  1. Sony Xperia Z2 Rear / Battery Cover Replacement, Rear / Battery Cover: step 1, image 1 of 3 Sony Xperia Z2 Rear / Battery Cover Replacement, Rear / Battery Cover: step 1, image 2 of 3 Sony Xperia Z2 Rear / Battery Cover Replacement, Rear / Battery Cover: step 1, image 3 of 3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Rear / Battery Cover Replacement: step 2, image 1 of 3 Sony Xperia Z2 Rear / Battery Cover Replacement: step 2, image 2 of 3 Sony Xperia Z2 Rear / Battery Cover Replacement: step 2, image 3 of 3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Rear / Battery Cover Replacement: step 3, image 1 of 2 Sony Xperia Z2 Rear / Battery Cover Replacement: step 3, image 2 of 2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
ZFix
191,470 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,483 Guides authored
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 29
All Time: 42,912
