Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement
Video Overview
  1. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement, Rear / Battery Cover: step 1, image 1 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement, Rear / Battery Cover: step 1, image 2 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement, Rear / Battery Cover: step 1, image 3 of 3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 2, image 1 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 2, image 2 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 2, image 3 of 3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 3, image 1 of 2 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 3, image 2 of 2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
    Should include the information about the NFC antenna.
    Sounds like a dealbreaker for some people.
    Diogo Pinheiro - Reply
    What about it?
    Makos - Reply
  4. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement, Battery: step 4, image 1 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement, Battery: step 4, image 2 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement, Battery: step 4, image 3 of 3
    Did you use the custom adhesive or the 3M double sided tape?
    kelvinteohbc - Reply
  5. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: step 5, image 1 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: step 5, image 2 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: step 5, image 3 of 3
    • Remove the Loudspeaker metal bracket.
  6. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 6, image 1 of 2 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 6, image 2 of 2
    • Remove the two Phillips screws that hold Loudspeaker/Vibromotor module.
    • Disconnect the Coaxial Antenna cable.
  7. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 7, image 1 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 7, image 2 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 7, image 3 of 3
    • With the sharp end of the plastic tool carefully subtract the module from the phone housing.
    • The Loud Speaker has some adhesive holding it to the chassis so a little heat on the front will help.
  8. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 8, image 1 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 8, image 2 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 8, image 3 of 3
    • Disconnect the Touchscreen flex cables.
    • Disconnect the LCD Display flex cable.
    • You can embed the Loudspeaker module to the phone housing with masking tape. This will prevent the ribbon from breaking.
  9. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 9, image 1 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 9, image 2 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 9, image 3 of 3
    • Use a transparent packaging tape and stick it on top of the glass. This will help you remove the broken glass later.
    • Preheat the Display.
    • Use a cutter to make a room for a plastic tool.
  10. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 10, image 1 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 10, image 2 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 10, image 3 of 3
    • Continue separating the display from the frame by using plastic opening tools.
  11. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 11, image 1 of 2 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 11, image 2 of 2
    • Clean the frame from the remains of tape.
    • Now it's time to test the new spare part.
  12. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 12, image 1 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 12, image 2 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 12, image 3 of 3
    • Use a high quality adhesive sticker for the model.
    • This will stick the display to the frame harder and it will save the waterproof ability of your phone.
  13. Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 13, image 1 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 13, image 2 of 3 Sony Xperia Z2 Display Assembly - Touch screen & LCD Display Replacement: step 13, image 3 of 3
    • Use again adhesive sticker to atach the back / battery cover.
    • All's well that ends well.
    Did it! It's pretty easy.
    Freek Wennekers - Reply
61 other people completed this guide.
ZFix
191,368 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,466 Guides authored
22 Comments
Worked! I very much recommend watching the video as well as read the manual to get a complete picture. My total time spent was multiple hours, but largely because it's the first time I'm doing a repair that involves so much glue. Gained a few gray hairs there.
Two stumbles:
I missed the line "The load Speaker has some adhesive holding it to the chassis so a little heat on the front will help.", which cost me a lot of time and worry as I was trying to force the speaker assembly out. Eventually got it out, and it's fine. Ribbon cables will be the death of me some day.
I did not keep the little bit of tape on the display ribbon safe and clean and ended up not using it at all. The written manual doesn't show its reuse, the video does.
Also: getting (almost) all of the glue goop off the back was a tragedy.
Minic - Reply
so cool, is simple.
danielassro - Reply
She lives, very nice guide! :D
Jroen - Reply
My Xperia Z2 touch screen is fixed at a phone repaircenter. I dont know what they do but since that day it looks like my touchscreen living his own life. Especially if i type some text with the stock keyboard. Its very frustrating and my question is.....can i do something about it myself?
Sorry for my bad English btw
Anita van Geel - Reply
Before gluing the screen to work well sensors and all that, you need to put some black tape on the camera or sensors?
Is it and seen online tutorials or is not necessary
Hector Gonzalez - Reply
I did not glue and it was fine.
Tech Sponge -
Hi,
i need to change my LCD , but i can't find an original parts for my Z2
can you tell me where i can buy a genuine original sony remplacment LCd+Digitizer ?
thanks
jean SUNSERI - Reply
Sony does not sell direct. To get a " genuine " replacement , you have to have the authorized service repair do it. Just buy one off ebay.
Tech Sponge -
Hey!
Thanks for this tutorial. Without this tutorial i would probably done something bad to my phone, but with it everything works!
I had a problem with separating backcover with battery, two screws that holds battery in place in my device didnt hold battery in place, when i pryed open backcover battery instead staying inside her place (inside device) she was glued to backcover and only flex cable was holding it to device. I think that way it was more difficult to separate battery from backcover, so if this happend to you too dont lose hope and have patience. I dont know why it was like that, but when i was closing cover i put effort to check anything was wrong with socket screws etc, but didnt find anything worth mentioning.
kociak0 - Reply
Please someone help me?
Where do I get the original touch display LCD to buy? For Sony Xperia Z2 D6543 or D6503
Pierre Psy - Reply
Hi bought LCDs from ebay and they worked well, but one hade weak tape so I neede to replace it. My last LCD I bought for another Z2 was from a repairstore in town.
Claes -
hi, i started disassembling my phone and 1 screw the one in right low side doenst move at all. can u help me guys
Nika Khintibidze - Reply
Do you have different size screwdrivers? It is sometimes possible to loosen ascrew with the wrong size screwdriver but much easier with the correct one. I think i have used Philips 0 or 00.
Claes -
replacement screen doesn't have Sony logo as pictured above.. installing tomorrow
Cody Viall - Reply
screen is garbage if you were scared off by all the reviews on amazon it is the same here (ghost touches, screen flickers like a crt tv, colors are washed out) installation was done professionally yet still has touch problems
Cody Viall - Reply
U got it from ifixit ??
dilip vishwanath -
I have bought two screens from Honkong/Shenzen over e-bay and they where good. The next two I bought from a repairshop in Stockholm also with a good quality.
Claes -
Hey.
My screen is cracked. No damage to the display.Could I only replace the touch screen glass without replacing the display?
Need a reply very soon.....
Rumaiz - Reply
I have not seen only the glass when I have looked for spare parts.
Claes - Reply
I also recommend watching the video as well as read the text in this guide. The guide missed out on a lot of details that I saw in the video. Without the video I think I would have been lost. For example "now it's time to test the new spare part". What? The guide doesn't show how to do that! But in the video it's easy to follow along.
It says that this was very hard, but I would say that it's moderate.
Krister - Reply
Sim is working only for some time after this repair, any solutions pls, I even rebooted+reset to be sure, need help fast,
Avinash Vishnu - Reply
Excellent thank you
المراكبي - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 36
All Time: 89,741
