Introduction
This guide will replace the external speaker in the Sony Xperia Z1 Compact.
Attach the small suction cup to the back cover near the bottom of the phone.
Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
Unscrew the four screws on the corners of the back frame using the J00 Phillips head.
Wedge the plastic spudger under the back frame. Move the spudger around the entire frame to separate it from the adhesive.
Wedge the spudger underneath the external speaker. Pull up on the external speaker using the spudger.
