Sony Xperia TL Display Assembly Replacement
  1. Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: step 1, image 1 of 3 Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: step 1, image 2 of 3 Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: step 1, image 3 of 3
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Display Assembly Replacement, Remove Bottom Plastic Section: step 2, image 1 of 2 Sony Xperia TL Display Assembly Replacement, Remove Bottom Plastic Section: step 2, image 2 of 2
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: step 3, image 1 of 3 Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: step 3, image 2 of 3 Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: step 3, image 3 of 3
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Display Assembly Replacement, Loud Speaker: step 4, image 1 of 3 Sony Xperia TL Display Assembly Replacement, Loud Speaker: step 4, image 2 of 3 Sony Xperia TL Display Assembly Replacement, Loud Speaker: step 4, image 3 of 3
    • Use the plastic opening tool to remove the loud speaker module.
  5. Sony Xperia TL Display Assembly Replacement, Battery: step 5, image 1 of 3 Sony Xperia TL Display Assembly Replacement, Battery: step 5, image 2 of 3 Sony Xperia TL Display Assembly Replacement, Battery: step 5, image 3 of 3
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
  6. Sony Xperia TL Display Assembly Replacement, Battery Harness: step 6, image 1 of 3 Sony Xperia TL Display Assembly Replacement, Battery Harness: step 6, image 2 of 3 Sony Xperia TL Display Assembly Replacement, Battery Harness: step 6, image 3 of 3
    • Unhook the 2 connections between the harness and phone shell.
    • Using the plastic opening tool, pry the harness up and remove it.
    • There is an adhesive on the bottom half of the battery harness.
  7. Sony Xperia TL Display Assembly Replacement: step 7, image 1 of 1
    • The final step is taking the entire harness off of the phone.
  8. Sony Xperia TL Display Assembly Replacement, Motherboard: step 8, image 1 of 3 Sony Xperia TL Display Assembly Replacement, Motherboard: step 8, image 2 of 3 Sony Xperia TL Display Assembly Replacement, Motherboard: step 8, image 3 of 3
    • Use the Phillips #00 to remove the 3 5mm screws.
    • Lift the plastic cover off.
    • Use the plastic opening tool to pry the motherboard out of the phone shell.
  9. Sony Xperia TL Display Assembly Replacement, Ear Speaker: step 9, image 1 of 1
    • Use the plastic opening tool to detach the ear piece speaker.
    • Avoid majorly bending the tiny metal hooks holding the ear piece in.
  10. Sony Xperia TL Display Assembly Replacement, Display Assembly: step 10, image 1 of 1
    • Once every single piece is removed from the main screen/digitizer this will be the only remaining piece. Nothing else can be removed. If you need to replace your screen this entire piece must be replaced.
Adam Giniger
1,303 Reputation
8 Guides authored
USF Tampa, Team 4-4, Brown Fall 2014 Member of USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 550
