Sony Xperia TL Battery Replacement
  1. Sony Xperia TL Battery Replacement, Remove Top Plastic Section: step 1, image 1 of 3 Sony Xperia TL Battery Replacement, Remove Top Plastic Section: step 1, image 2 of 3 Sony Xperia TL Battery Replacement, Remove Top Plastic Section: step 1, image 3 of 3
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Battery Replacement, Remove Bottom Plastic Section: step 2, image 1 of 2 Sony Xperia TL Battery Replacement, Remove Bottom Plastic Section: step 2, image 2 of 2
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Battery Replacement, Unscrewing the Back Off: step 3, image 1 of 3 Sony Xperia TL Battery Replacement, Unscrewing the Back Off: step 3, image 2 of 3 Sony Xperia TL Battery Replacement, Unscrewing the Back Off: step 3, image 3 of 3
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Battery Replacement, Battery: step 4, image 1 of 3 Sony Xperia TL Battery Replacement, Battery: step 4, image 2 of 3 Sony Xperia TL Battery Replacement, Battery: step 4, image 3 of 3
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
4 other people completed this guide.
Adam Giniger
1,303 Reputation
8 Guides authored
USF Tampa, Team 4-4, Brown Fall 2014 Member of USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 Members
10 Guides authored
One Comment
Is it necessary to back up the phone before replacing the battery, or will the settings be preserved?
r3woods - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 2,046
