Sony Xperia S Disassembly
  1. Sony Xperia S Disassembly, Sony Xperia S Disassembly: step 1, image 1 of 1
    • Remove the case (back cover)
  2. Sony Xperia S Disassembly: step 2, image 1 of 1
    • Remove the screws in the indicated areas (Red Markings) with a screwdriver.
  3. Sony Xperia S Disassembly: step 3, image 1 of 1
    • Then, detach the first bus (indicated with the red circle) to fully detach the case.
  4. Sony Xperia S Disassembly: step 4, image 1 of 1
    • Then, you will see the battery, let's proceed to remove the battery.
  5. Sony Xperia S Disassembly: step 5, image 1 of 1
    • To remove the battery, remove the two buses pointed out in red.
  6. Sony Xperia S Disassembly: step 6, image 1 of 1
    • After removing the buses, we can remove the camera and the motherboard. Proceed to remove the motherboard.
  7. Sony Xperia S Disassembly: step 7, image 1 of 1
    • Finally, after removing the motherboard, you have fully dismantled the phone.
To reassemble your device, follow the instructions in reverse order
3 other people completed this guide.
Special thanks to these translators:
es en
100%
Henry Ko is helping us fix the world! Want to contribute?
Start translating ›
sergiolisto95
118 Reputation
1 Guide authored
3 Comments
hi..my xperia s totally crashed..it is not working at all..is there any way to get the data from the sd card..!!??please help..if i disassembled it ..can i run the sd card on another device or something like that or any thing ..please help..:(
soma ana - Reply
Hi Soma Ana,
Assuming that your SD card has not been corrupted or anything, you can plug it into your computer or another device (though I would personally recommend you to look from your computer) and find your old files.
Henry Ko -
estoy en la misma situaciĆ³n, pudiste encontrar la sd?
Leopold Fitz -
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 25
All Time: 3,073
