Sony Walkman D-E356CK Back Panel Replacement
    1. Sony Walkman D-E356CK Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Open the battery compartment.
      • Remove the AA batteries from within the compartment.
      Ask FixBot
    2. Sony Walkman D-E356CK Back Panel Replacement: step 2, image 1 of 3 Sony Walkman D-E356CK Back Panel Replacement: step 2, image 2 of 3 Sony Walkman D-E356CK Back Panel Replacement: step 2, image 3 of 3
      • Press the button located in the bottom left corner of the device labeled "open."
      • Remove the three 11 mm-long Phillips screws.
      Ask FixBot
    3. Sony Walkman D-E356CK Back Panel Replacement: step 3, image 1 of 2 Sony Walkman D-E356CK Back Panel Replacement: step 3, image 2 of 2
      • Remove the two 11 mm-long Phillips screws on the back side of the Walkman.
      Ask FixBot
    4. Sony Walkman D-E356CK Back Panel Replacement: step 4, image 1 of 2 Sony Walkman D-E356CK Back Panel Replacement: step 4, image 2 of 2
      • Insert an opening tool into the seam between the back panel and chassis.
      • Pry around the perimeter until the back panel releases.
      • Remove the back panel.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Aiden Pacheco
136 Reputation
1 Guide authored
UMass Dartmouth, Team 1-1, Botvin Fall 2025 Member of UMass Dartmouth, Team 1-1, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 33
All Time: 167
