Sony WH-1000XM5 Touch Sensor Replacement
    1. Sony WH-1000XM5 Touch Sensor Replacement, Earpads: step 1, image 1 of 3 Sony WH-1000XM5 Touch Sensor Replacement, Earpads: step 1, image 2 of 3 Sony WH-1000XM5 Touch Sensor Replacement, Earpads: step 1, image 3 of 3
      Tool used on this step:
      iFixit Opening Tool
      $1.99
      Buy
      • Place the edge of an iFixit opening tool under the earpad cushion.
      • Slide it alongside the edge of the cushion until it detaches from the rest of the headphones.
      Ask FixBot
    1. Sony WH-1000XM5 Touch Sensor Replacement, Touch Sensor: step 2, image 1 of 2 Sony WH-1000XM5 Touch Sensor Replacement, Touch Sensor: step 2, image 2 of 2
      • Remove the eight 2.4mm screws located inside the right ear cup using a Phillips #000 screwdriver.
      Ask FixBot
    2. Sony WH-1000XM5 Touch Sensor Replacement: step 3, image 1 of 3 Sony WH-1000XM5 Touch Sensor Replacement: step 3, image 2 of 3 Sony WH-1000XM5 Touch Sensor Replacement: step 3, image 3 of 3
      • Flip the headphones over.
      • Carefully lift the plastic cover slightly, but do not remove it completely.
      • The touch sensor has a ribbon cable connected to the mainboard.
      • Gently grab the ribbon cable and pull away from the connector to disconnect it.
      • Do not attempt to remove the touch sensor; it is glued to the plastic ear cup cover.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 189
All Time: 2,482
