Installing Sony Vaio PCG-6J2L Speaker Assembly
  1. Installing Sony Vaio PCG-6J2L Speaker Assembly, Battery: step 1, image 1 of 1
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Installing Sony Vaio PCG-6J2L Speaker Assembly: step 2, image 1 of 1
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Installing Sony Vaio PCG-6J2L Speaker Assembly, Keyboard: step 3, image 1 of 1
    • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Remove the Torx security screw near the center of the battery-side edge.
  4. Installing Sony Vaio PCG-6J2L Speaker Assembly: step 4, image 1 of 2 Installing Sony Vaio PCG-6J2L Speaker Assembly: step 4, image 2 of 2
    • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
    • Pull the keyboard toward the mouse pad and gently lift up.
  5. Installing Sony Vaio PCG-6J2L Speaker Assembly: step 5, image 1 of 2 Installing Sony Vaio PCG-6J2L Speaker Assembly: step 5, image 2 of 2
    • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
    • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • Remove the keyboard.
  6. Installing Sony Vaio PCG-6J2L Speaker Assembly, Mouse Assembly: step 6, image 1 of 1
    • Turn the laptop upside down.
    • Remove the three screws from the front mouse panel located on the bottom of the laptop.
    • Carefully flip the laptop back over. Remove three more screws from the top securing the panel. A ribbon cable will still be attached to the panel when you remove it.
  7. Installing Sony Vaio PCG-6J2L Speaker Assembly: step 7, image 1 of 2 Installing Sony Vaio PCG-6J2L Speaker Assembly: step 7, image 2 of 2
    • Lift the mouse assembly just enough to access the connecting ribbon cable.
    • Lift the ribbon cable lock to remove the cable.
    • Carefully remove the mouse panel assembly and set aside.
  8. Installing Sony Vaio PCG-6J2L Speaker Assembly, Speaker Assembly: step 8, image 1 of 3 Installing Sony Vaio PCG-6J2L Speaker Assembly, Speaker Assembly: step 8, image 2 of 3 Installing Sony Vaio PCG-6J2L Speaker Assembly, Speaker Assembly: step 8, image 3 of 3
    • Remove the four screws from the underside of the computer. These screws are located underneath where the battery sits and secure the top keyboard panel.
    • To remove the panel below the screen, press up on the two tabs holding the panel in and lift up. The panel should pop off.
    • Before proceeding, remove all black tape holding down wires and other cabling.
  9. Installing Sony Vaio PCG-6J2L Speaker Assembly: step 9, image 1 of 1
    • Pop off the antenna using a pair of tweezers.
  10. Installing Sony Vaio PCG-6J2L Speaker Assembly: step 10, image 1 of 1
    • Remove the seven philips screws holding the speaker assembly in place.
    • Before removing the assembly, disconnect the ribbon cable located at the top left corner of the assembly.
    • The speaker assembly will come off with the display assembly.
Ryan
154 Reputation
2 Guides authored
Cal Poly, Team 25-89, Amido Spring 2010 Member of Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Members
63 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 4,403
