Sony Vaio VGN-SZ120P Keyboard Replacement
  1. Sony Vaio VGN-SZ120P Keyboard Replacement, Battery: step 1, image 1 of 1
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio VGN-SZ120P Keyboard Replacement: step 2, image 1 of 1
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio VGN-SZ120P Keyboard Replacement, Keyboard: step 3, image 1 of 1
    • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Remove the Torx security screw near the center of the battery-side edge.
  4. Sony Vaio VGN-SZ120P Keyboard Replacement: step 4, image 1 of 2 Sony Vaio VGN-SZ120P Keyboard Replacement: step 4, image 2 of 2
    • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
    • Pull the keyboard toward the mouse pad and gently lift up.
  5. Sony Vaio VGN-SZ120P Keyboard Replacement: step 5, image 1 of 2 Sony Vaio VGN-SZ120P Keyboard Replacement: step 5, image 2 of 2
    • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
    • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • Remove the keyboard.
Ashley Brooks
312 Reputation
4 Guides authored
Cal Poly, Team 25-89, Amido Spring 2010 Member of Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Members
63 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 5,530
