Sony Vaio Pro 13 Bottom Cover Replacement
  1. Sony Vaio Pro 13 Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 2 Sony Vaio Pro 13 Bottom Cover Replacement, Bottom Cover: step 1, image 2 of 2
    • Remove cover for the extended battery connector. Use your finger nail or a plastic opening tool to remove it.
    • Remove the two rubber feet at the back of the computer, these can be removed in the same way.
  2. Sony Vaio Pro 13 Bottom Cover Replacement: step 2, image 1 of 2 Sony Vaio Pro 13 Bottom Cover Replacement: step 2, image 2 of 2
    • Remove the four 5.6mm Philips #00 screws located at the top of the computer.
    • Remove the eight 3.6mm Philips #00 screws on the base of the computer.
  3. Sony Vaio Pro 13 Bottom Cover Replacement: step 3, image 1 of 2 Sony Vaio Pro 13 Bottom Cover Replacement: step 3, image 2 of 2
    • Using a plastic opening tool, pry the plastic casing away from the base of the computer, the remaining clips around the edges can be released using your hands.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 27
All Time: 6,953
