Sony Vaio VGN-NW240F (PCG-7184L) Network Card Replacement
  1. Sony Vaio VGN-NW240F (PCG-7184L) Network Card Replacement, Battery: step 1, image 1 of 1
    • Power off the laptop.
    • Unplug the charging cable and any other cables plugged into the laptop.
    • Failure to remove or unplug any cables could result in electric shock.
    • Turn the laptop over so that the back panel is facing upwards.
  2. Sony Vaio VGN-NW240F (PCG-7184L) Network Card Replacement: step 2, image 1 of 1
    • Locate two switches above the battery that lock it into place.
    • Push the left-hand switch, that says "lock" above it, so that it is unlocked.
  3. Sony Vaio VGN-NW240F (PCG-7184L) Network Card Replacement: step 3, image 1 of 1
    • Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
  4. Sony Vaio VGN-NW240F (PCG-7184L) Network Card Replacement, Optical Drive: step 4, image 1 of 1
    • Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
    • There will be three dots next to the desired screws
  5. Sony Vaio VGN-NW240F (PCG-7184L) Network Card Replacement: step 5, image 1 of 1
    • Grip the cover of the optical drive and slide it out.
    • If it does not come out, do not force it. Double check to make sure the screws are entirely removed.
  6. Sony Vaio VGN-NW240F (PCG-7184L) Network Card Replacement, Back Panel: step 6, image 1 of 3 Sony Vaio VGN-NW240F (PCG-7184L) Network Card Replacement, Back Panel: step 6, image 2 of 3 Sony Vaio VGN-NW240F (PCG-7184L) Network Card Replacement, Back Panel: step 6, image 3 of 3
    • Remove all the 8mm Phillips #1 screws on the backside of the laptop.
    • There are three 3mm and two 5.3mm screws under the battery that also need to be taken out.
    • There are three 3mm screws under the optical drives that also need to be taken out.
    • Remove the RAM panel in addition to the other screws. For further instructions, refer to the RAM replacement guide.
  7. Sony Vaio VGN-NW240F (PCG-7184L) Network Card Replacement: step 7, image 1 of 3 Sony Vaio VGN-NW240F (PCG-7184L) Network Card Replacement: step 7, image 2 of 3 Sony Vaio VGN-NW240F (PCG-7184L) Network Card Replacement: step 7, image 3 of 3
    • Pry along the edges of the back panel using the spudger.
    • If you are struggling to remove the back panel with a moderate amount of force, do NOT apply any additional force, instead double check to make sure all the screws were removed before attempting again.
  8. Sony Vaio VGN-NW240F (PCG-7184L) Network Card Replacement, Network Card: step 8, image 1 of 1
    • Pull the two cables off of the network card.
    • Make sure to pull the cables straight up as the connectors are fragile.
  9. Sony Vaio VGN-NW240F (PCG-7184L) Network Card Replacement: step 9, image 1 of 1
    • Remove the two Phillips 5.3mm screws from the network card.
    • After the screws are released, the network chip should lift up at an angle.
    • Gently pull out the network card.
Sid
311 Reputation
2 Guides authored
Cal Poly, Team 9-17, Regan Spring 2014 Member of Cal Poly, Team 9-17, Regan Spring 2014
CPSU-REGAN-S14S9G17
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 21
All Time: 2,238
