Sony Vaio VGN-SZ120P Mouse Assembly Replacement
    1. Sony Vaio VGN-SZ120P Mouse Assembly Replacement, Battery: step 1, image 1 of 1
      • Set the computer display-side down.
      • Unlock the battery by sliding the port-side latch to the 'unlock' position.
      Ask FixBot
    2. Sony Vaio VGN-SZ120P Mouse Assembly Replacement: step 2, image 1 of 1
      • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
      Ask FixBot
    1. Sony Vaio VGN-SZ120P Mouse Assembly Replacement, Keyboard: step 3, image 1 of 1
      • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
      • Remove the Torx security screw near the center of the battery-side edge.
      Ask FixBot
    2. Sony Vaio VGN-SZ120P Mouse Assembly Replacement: step 4, image 1 of 2 Sony Vaio VGN-SZ120P Mouse Assembly Replacement: step 4, image 2 of 2
      • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
      • Pull the keyboard toward the mouse pad and gently lift up.
      Ask FixBot
    3. Sony Vaio VGN-SZ120P Mouse Assembly Replacement: step 5, image 1 of 2 Sony Vaio VGN-SZ120P Mouse Assembly Replacement: step 5, image 2 of 2
      • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
      • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
      • Remove the keyboard.
      Ask FixBot
    1. Sony Vaio VGN-SZ120P Mouse Assembly Replacement, Mouse Assembly: step 6, image 1 of 1
      • Turn the laptop upside down.
      • Remove the three screws from the front mouse panel located on the bottom of the laptop.
      • Carefully flip the laptop back over. Remove three more screws from the top securing the panel. A ribbon cable will still be attached to the panel when you remove it.
      Ask FixBot
    2. Sony Vaio VGN-SZ120P Mouse Assembly Replacement: step 7, image 1 of 2 Sony Vaio VGN-SZ120P Mouse Assembly Replacement: step 7, image 2 of 2
      • Lift the mouse assembly just enough to access the connecting ribbon cable.
      • Lift the ribbon cable lock to remove the cable.
      • Carefully remove the mouse panel assembly and set aside.
      Ask FixBot
3 other people completed this guide.
Ashley Brooks
312 Reputation
4 Guides authored
Cal Poly, Team 25-89, Amido Spring 2010 Member of Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Members
563 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 98
All Time: 4,119
