Sony Vaio VPCCW17FX LCD Screen Replacement
  1. Sony Vaio VPCCW17FX LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX LCD Screen Replacement: step 2, image 1 of 1
    • Slide both latches towards the center of the battery to release.
  3. Sony Vaio VPCCW17FX LCD Screen Replacement: step 3, image 1 of 2 Sony Vaio VPCCW17FX LCD Screen Replacement: step 3, image 2 of 2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX LCD Screen Replacement: step 4, image 1 of 2 Sony Vaio VPCCW17FX LCD Screen Replacement: step 4, image 2 of 2
    • Remove the rubber pads on all four corners of the screen bezel using the spudger.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver.
  5. Sony Vaio VPCCW17FX LCD Screen Replacement: step 5, image 1 of 1
    • Remove the screen's plastic bezel.
    • You need to use slight pressure to release the clips.
  6. Sony Vaio VPCCW17FX LCD Screen Replacement: step 6, image 1 of 2 Sony Vaio VPCCW17FX LCD Screen Replacement: step 6, image 2 of 2
    • Remove all four screws (Length: 7.7 mm) using a Phillips #0 screwdriver. Make sure to hold the screen while removing the screws so it doesn't fall.
    • Using your thumb, carefully lower the glass and place it on the keyboard.
    • Do this slowly to avoid damaging the screen.
  7. Sony Vaio VPCCW17FX LCD Screen Replacement: step 7, image 1 of 2 Sony Vaio VPCCW17FX LCD Screen Replacement: step 7, image 2 of 2
    • Pull off the tape and disconnect the display cable connector by gently sliding up to remove it from its socket.
  8. Sony Vaio VPCCW17FX LCD Screen Replacement: step 8, image 1 of 1
    • The screen can now be removed.
Seowon Song
113 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 13
All Time: 1,097
