Sony Vaio VGN-SR140E Screen Replacement
  1. Sony Vaio VGN-SR140E Screen Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Screen Replacement: step 2, image 1 of 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Screen Replacement: step 3, image 1 of 2 Sony Vaio VGN-SR140E Screen Replacement: step 3, image 2 of 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E Screen Replacement, Screen: step 4, image 1 of 3 Sony Vaio VGN-SR140E Screen Replacement, Screen: step 4, image 2 of 3 Sony Vaio VGN-SR140E Screen Replacement, Screen: step 4, image 3 of 3
    • Remove the rubber pads at all four corners of the screen bezel using a spudger. This will reveal four 5mm Phillips screws.
    • Use a Phillips #1 screwdriver to remove the four screws and set them aside.
  5. Sony Vaio VGN-SR140E Screen Replacement: step 5, image 1 of 1
    • Remove the screen's plastic bezel. You may need to use slight pressure to release the clips that secure the bezel to the laptop.
  6. Sony Vaio VGN-SR140E Screen Replacement: step 6, image 1 of 2 Sony Vaio VGN-SR140E Screen Replacement: step 6, image 2 of 2
    • Lift screen bezel up and off of the laptop.
  7. Sony Vaio VGN-SR140E Screen Replacement: step 7, image 1 of 3 Sony Vaio VGN-SR140E Screen Replacement: step 7, image 2 of 3 Sony Vaio VGN-SR140E Screen Replacement: step 7, image 3 of 3
    • Close the laptop carefully and slowly while holding the screen with your thumb to prevent it from falling.
    • Lay the screen gently on the keyboard. This will reveal the screen's connector.
  8. Sony Vaio VGN-SR140E Screen Replacement: step 8, image 1 of 3 Sony Vaio VGN-SR140E Screen Replacement: step 8, image 2 of 3 Sony Vaio VGN-SR140E Screen Replacement: step 8, image 3 of 3
    • Grasp the connector and gently pull it out.
  9. Sony Vaio VGN-SR140E Screen Replacement: step 9, image 1 of 1
    • The screen can now be removed.
Jeremy
722 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 14
All Time: 1,124
