Community-Contributed Guide
Introduction
Go to step 1 ↓This guide is very easy to complete, because back in the day computers were easier to take apart! Hope you enjoy. The only thing is that I cannot find replacement RAM, so if you can find replacement RAM for this particular machine I will include you in the honorable mentions. A picture of the RAM with the label is on step 1 on the second photo.
Tools
Flip the computer over, and remove all screws circled in picture provided.
Flip the computer over and open the lid. Then take the trackpad/wrist-rest off the computer slightly but not too fast because there is a ribbon cable to disconnect. Once you have disconnected the ribbon cable set aside the assembly
Push the two white pieces holding the RAM aside and then push the RAM up.
Remove the RAM from the computer and set it aside.
Insert your replacement RAM into the slot, then push down gently until the plastic holders click and hold the RAM into place.
Re-connect the ribbon cable from the trackpad/wrist-rest, then place the assembly down onto it’s mount and close the computer lid, and then flip it back over.
To reassemble your device, follow step 1 in reverse order.
