Introduction
This guide will show you how to identify and properly remove the hard drive for the Sony Vaio Fit SVF15N26CXB. Use the project mat to keep the screws organized.
Remove the following ten screws from the bottom case of the laptop:
Two 6.5mm Phillips #00 Phillips screws.
Four 8.95mm Phillips #00 screws.
Four 6.25mm Phillips #00 screws.
Use a plastic opening tool to separate the bottom cover from the laptop.
Lift the lower cover and pull away from the laptop.
Gently remove the cable ribbons that are silver and gold by opening the locking mechanism and pulling both out.
Remove pin connector from the back side of the hard drive by pinching and pulling it off.
Remove (4) 3.70mm PH00 phillips head screws that connects to the case of the hard drive.
Carefully peel foil tray off of hard drive.
