Installing the Sony VAIO VPC-EB33FM Fan
  1. Installing the Sony VAIO VPC-EB33FM Fan, Battery: step 1, image 1 of 2 Installing the Sony VAIO VPC-EB33FM Fan, Battery: step 1, image 2 of 2
    • Power down the laptop by pressing the power button.
    • Turn the laptop onto its backside.
  2. Installing the Sony VAIO VPC-EB33FM Fan: step 2, image 1 of 1
    • To release the battery, hold both the release button and the unlock button at the same time.
  3. Installing the Sony VAIO VPC-EB33FM Fan: step 3, image 1 of 2 Installing the Sony VAIO VPC-EB33FM Fan: step 3, image 2 of 2
    • Remove the battery out from the notch while continuing to hold the release button.
  4. Installing the Sony VAIO VPC-EB33FM Fan, Hard Drive: step 4, image 1 of 3 Installing the Sony VAIO VPC-EB33FM Fan, Hard Drive: step 4, image 2 of 3 Installing the Sony VAIO VPC-EB33FM Fan, Hard Drive: step 4, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the two 7.8 mm cover screws on the bottom corners of the panel.
  5. Installing the Sony VAIO VPC-EB33FM Fan: step 5, image 1 of 3 Installing the Sony VAIO VPC-EB33FM Fan: step 5, image 2 of 3 Installing the Sony VAIO VPC-EB33FM Fan: step 5, image 3 of 3
    • Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
    • You may need to use your other hand to safely remove the panel.
    • You can also use a spudger for this step.
  6. Installing the Sony VAIO VPC-EB33FM Fan: step 6, image 1 of 1
    • Remove the two remaining 7.8 mm screws using the Phillips #00 screwdriver.
  7. Installing the Sony VAIO VPC-EB33FM Fan: step 7, image 1 of 1
    • Grab the tab between your thumb and index finger.
    • Hold the hard drive securely in a horizontal position using your other hand.
    • Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
    • To prevent damage of the connection on the hard disk drive or the laptop, perform this task slowly and with care.
  8. Installing the Sony VAIO VPC-EB33FM Fan: step 8, image 1 of 2 Installing the Sony VAIO VPC-EB33FM Fan: step 8, image 2 of 2
    • While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle.
    • Pull the hard drive out.
  9. Installing the Sony VAIO VPC-EB33FM Fan: step 9, image 1 of 2 Installing the Sony VAIO VPC-EB33FM Fan: step 9, image 2 of 2
    • If you need to remove the bracket from the hard drive, follow the next few steps:
    • Remove the two 3.7 mm screws from either side of the bracket with a Phillips #00 screwdriver.
    • Lift the bracket off the hard drive.
  10. Installing the Sony VAIO VPC-EB33FM Fan, RAM: step 10, image 1 of 3 Installing the Sony VAIO VPC-EB33FM Fan, RAM: step 10, image 2 of 3 Installing the Sony VAIO VPC-EB33FM Fan, RAM: step 10, image 3 of 3
    • Remove the one screw with a Phillips #00 screwdriver.
    • The screw cannot be removed from the RAM casing cover.
  11. Installing the Sony VAIO VPC-EB33FM Fan: step 11, image 1 of 2 Installing the Sony VAIO VPC-EB33FM Fan: step 11, image 2 of 2
    • Pull the two retaining arms away from the center of the RAM chip.
    • The RAM will make a "pop" sound and the RAM stick will rise for ease of handling.
  12. Installing the Sony VAIO VPC-EB33FM Fan: step 12, image 1 of 3 Installing the Sony VAIO VPC-EB33FM Fan: step 12, image 2 of 3 Installing the Sony VAIO VPC-EB33FM Fan: step 12, image 3 of 3
    • Pull the RAM stick out of its socket.
    • To remove the second stick of RAM, repeat steps six and seven.
    • When installing RAM, make sure sticks are firmly in place or the computer will not register them.
  13. Installing the Sony VAIO VPC-EB33FM Fan, Fan: step 13, image 1 of 1
    • Remove the following 16 screws securing the back cover using a Phillips #00 screwdriver:
    • Two 3.8-mm screws
    • Two 8.9-mm screws
    • Twelve 7.75-mm screws
  14. Installing the Sony VAIO VPC-EB33FM Fan: step 14, image 1 of 1
    • Check to make sure all the screws have been removed.
    • Using both hands, separate the back cover by lifting from the back and working around the perimeter to release tabs.
  15. Installing the Sony VAIO VPC-EB33FM Fan: step 15, image 1 of 2 Installing the Sony VAIO VPC-EB33FM Fan: step 15, image 2 of 2
    • Locate the fan and the processor attachment.
  16. Installing the Sony VAIO VPC-EB33FM Fan: step 16, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the top four 3.88-mm fan screws.
  17. Installing the Sony VAIO VPC-EB33FM Fan: step 17, image 1 of 1
    • Remove the two 5.7-mm screws located at the base of the fan, using a Phillips #00 screwdriver.
  18. Installing the Sony VAIO VPC-EB33FM Fan: step 18, image 1 of 1
    • Pull back the tape located on the far side of the fan.
  19. Installing the Sony VAIO VPC-EB33FM Fan: step 19, image 1 of 1
    • Remove the wired connection between the fan and the copper wire using metal tweezers.
    • Do not to pull on the wires directly or it will damage the connection between the fan and the laptop.
  20. Installing the Sony VAIO VPC-EB33FM Fan: step 20, image 1 of 1
    • Remove the four 5.65-mm screws on the processor corners using a Phillips #00 screwdriver.
  21. Installing the Sony VAIO VPC-EB33FM Fan: step 21, image 1 of 2 Installing the Sony VAIO VPC-EB33FM Fan: step 21, image 2 of 2
    • You are now ready to remove fan and processor connection
    • Position thumbs and index fingers close to processor and lift up on the copper wire, while applying slight downward pressure on the motherboard with remaining fingers.
    • If there is thermal paste between the processor and the fan attachment, increased force will be required to detach the fan.
Kevin
513 Reputation
3 Guides authored
Cal Poly, Team 18-39, Regan Winter 2013 Member of Cal Poly, Team 18-39, Regan Winter 2013
CPSU-REGAN-W13S18G39
5 Members
15 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 19
All Time: 20,236
